Chris you inspired me: First PIC post
Bob Fawcett
>This is my most recent attempt at a bed post for a 4 poster bed SWMBO wants me to make. The post is made of Sapele. It is 3" square in the middle. I got the shape from ShopSmiths website. I blew up the plan they posted to near full size and used the drawing for pattern.
This post is 36" tall and is the bottom portion of the bed post. There is also a top portion that completes the post. I haven't tried to turn that yet.
This was turned as a "practice" post, but I may actually use it. I did turn 2 other slightly undersized ones prior to this as practice and to test proportions against the mattress. We bought a new mattress last year, and mattresses have grown tallllll recently. This one is 15" instead of about 8" for the previous one. I am talking about just the mattress, the box spring adds another 8". I had to strech the square portion of the post so it looks right against the mattress.
My Jet Mini is at the limit for this post. If I don't center the wood exactly, it wants to vibrate a LOT. Any tips for centering large spindles like this? I guess that its just a matter of precision.
Re: Chris you inspired me: First PIC post
tek-Brunswick, Ohio
>That post looks fine to me. You can draw lines from corner to corner on the end; where they intersect is the center. Center punch the spot for your drive and tail centers to line up in. With that square center section a spindle steady wouldn't be much help. Try different speeds sometimes a higher or lower speed will dampen the vibration. How do oyou have your mini mounted? If you can add some weight to the stand (sandbags?) it will help dampen vibration also. That is a nice project.
Tom
Brad Vietje
Brad Vietje
>Looks excellent, Bob!
How do you plan to get 'em all alike ? A friend of mine has a pretty cool method that involves mounting two exact duplicate copies of the profile behind the lathe so you can see any mismatch between your turning and the two drawings -- contact me off-list if you want, and I'll give you his contact info.
By the way ... sounds like it's time for a bigger lathe !
Safe spinning,
Brad Vietje
Newbury, VT
Bob Fawcett
>I agree on the bigger lathe. I am looking at the PM3520. Now if I convince SWMBO....
I think I saw something about that method on the net. Current plan is do the best I can at copying the one I have. It looks a lot like the plan I started with. I have the plan draped across a piece of hardboard that stands behind the lathe. I use calipers and measurements at various locations.
I showed this to a friend and he said "I think you should make all 4 posts different" I told him I was sure I would, I just don't know yet how much different they will be. Hopefully I can make them close enough to the same that you can't tell when they are on 4 corners of the bed
Bob Fawcett
>I sometimes have to slow down to 500RPM (lowest speed). I have 3 concrete "rocks" (bags of concrete I left outside under a tarp too long) on the bottom shelf of the lathe stand. This makes it as stable as I think I can get with a Jet Mini.
I started using the center finder and drawing from all 4 corners of the blank. If the blank is off square or one side slightly shorter, I get 4 lines, then my center is the middle of # the intersections. This last blank I got better at squareing it up on the jointer, and then ran it through the last planer setting on all surfaces. This makes it as close as I can get to dead square.
Rick Davenport
>Nice job!
You're off to a blazing start.
It's refreshing to see some quality spindle work.
Hope the boss okays the pm3520.
I've had mine for just a few weeks and love it.
Rick
PM3520
Bob Fawcett
>Who did you get it from?
Did you have it shipped to your shop or the terminal?
What tools are required for assembly/disassembly?
I will probably pick it up at the terminal to save the $85. With the help of a friend or 2 I can load it into the truck disassembled.
Any words to the wise?
Re: PM3520 *LINK*
Rick Davenport
>Bob,
I got my PM from Equipment Sales & Surplus in Auburn, WA
http://www.equipmentsalesandsurplus.com
Sometimes they have special deals on less than perfect machines.
They have outstanding customer service, good pricing and reasonable shipping rates.
I had mine lift gate delivered to my home. It cost an extra $40 for the lift gate, but worth it to me.
No special tools needed, but keep in mind it's a 220 power connection.
It's well packaged and arrived intact.
I took the headstock and tail stock off the bed.
Put the bed upside down on an old hunk of carpet.
Attached the legs.
Stood it upright and moved it into place.
Put the head and tailstocks back on, leveled it, plugged it in to 220 and that's it!
It takes at least two people.
It's a sweet unit!!!!
Rick
Equipment Sales and Surplus
Re: PM3520
Bob Fawcett
>Thanks Rick,
Auburn WA is a loooong way from me. Savannah GA.
I found it closer to home in a package that includes the 18" bed extension and tool rest extension for bowls on the end, the remote switch, and a bowl rest. I would have bought most of these anyway. Price looks comparable to what is posted at the site in your link.
Shipping is free, but lifgate is $85 extra. I think I will pick up at the terminal.
