First Try at This!
First Try at This!
First Try at This!
Chris DiCiaccio
>I know this looks pitiful, but I guess you have to start somewhere. It's not hollowed, just drilled with a forstner bit. Just working on shape right now. Hope to learn to hollow soon since I now have a Hollowmaster. Just don't know how to use it yet. Tried it but it didn't seem to want to cut.
Re: First Try at This!
Chris DiCiaccio
Chris DiCiaccio
Chris DiCiaccio
Bob Fawcett
>Chris
I like your enthusiam. I am new to this as well, just not as brave in posting photos of my attempts at turning. Guess I should get out the camera and get some feedback.
I like the shape.
Tell us what you are attempting. I guess it is meant be a box with top or hollow form with top. What is the light wood?
Chris DiCiaccio
>Well, it's supposed to be practice for a hollow form. The base is hard maple and the top is "spalted something" I found in the yard. The base measures 4" x 1 1/2". The forstner hole is 1 3/8".
Allen Neighbors
>Go for it, Chris! Just take a gouge and dig out the inside as much as you can. Then re-read all you can on your hollowing system, and practice, practice, practice. For a first try, I think you did pretty good. I think it needs just a little more daintiness (if that's the right word) on the finial/top... I said, "I think"... and it wouldn't overpower the vessel quite as much. Anyway, it sure looks a lot better than my first try at a hollowform. :o)
Allen
Bob Fawcett
>I knew that. (duh). I reread your first post and it dawned on me I knew that when I asked.
I took the chainsaw to a fallen tree at the side of the driveway I share with neighbors. Turned out to be spalted oak. I have 2 roughed out green wood bowls, a blank, and one I gave a friend who turns. There is still a lot of wood left. Need to take the chainsaw back to the tree. Turned out to be pretty nice looking wood.
That's not pitiful, Chris.
Eddie Pacheco, San Jose, Ca.
>Sure there are a lot of top dawg turners here, but they are the folks that inspire us to try harder.
Did you sharpen all of the bits that came with your Hollowmaster? Keep trying with it and you'll get the hang of it.
Eddie/Sharpening question
Chris DiCiaccio
>No, I haven't sharpened the bits yet. I asked the guy at woodcraft when I bought it if they were ready to cut or needed sharpening and he said they were ready to cut. This is my first use with it. Also, I've heard conflicting suggestions on sharpening these two bits. Sorby says use diamond stone and hone, others say make a jig and use your grinder, others say, don't use the grinder. I would like to be sure which method before I mess them up.
Re: Eddie/Sharpening question
>Chris, mine had a nick on the cutter when I got it and I had to sharpen it. I just used the grinder with the table set for 25-30 degrees from flat, and held the bit with my fingers, round side down, on the fine or white wheel of my grinder. A safer way is with a jig made of sq. alu. or steel bar stock with a hole for the cutter and a threaded side hole for a set screw to secure the cutter.
Also, the picture on the Woodcraft site shows the cutter tip on the wrong side of the locking screw. The cutter should be at the top of the screw when holding the tool in your hand and looking at the "Robert Sorbey" engraving on the shaft. Last week there was a posting on this and that's when the proper way of using this tool came up. I was using it as received until last weeks discussion and was getting a lot of cutter chatter while using the tool.
Good luck.
