Need some help
Need some help
Need some help
Timmy
>Well I do. Can someone of you tell me the best way for to cut the inside of a box. I'm using the spindle gouge but it doesn't exactly cut like I think that it should. Maybe this is the grain that makes it hard to do. Can someone help me? Thanks to you that can answer me.
Re: Need some help
Re: Need some help
>You didn's say whether it was an end grain box or a side grain box. For end grain boxes a spinle gouge will work well although I usually us a side ground bowl gouge. With either tool I start with the flute pointing about 10 oclock (your angle may vary depending on your tool and how it's sharpened). I should tell you that I drill out the inside to the proper depth first. I use the bowl gouge to do it but you can use a drill bit. Anyway I start at the hole and start the cut with the flute at about 10. I sort of lever the gouge with my left hand as the pivot point. The Cut goes from the middle out to the edge. the left hand edge of the gouge cutting edge is what does the cutting and it's more of a scrape but you do get good shavings.
With a bowl gouge I tilt the flute a little more toward 9 oclcock. If you don't feel comfortable with this a round nose scraper works great for end grain boxes. I grind the left edge so the it is ground from the front all the way around to the side. Start the cut from the center and again pivot it toward the edge. As the box gets deeper you can clean up the left inside of the box with that ground side of the scraper.
I'll check later tonight to see if you have any questions I have to go back to work now.
Re: Need some help
Re: Need some help *LINK*
Bob Fawcett
>Go here and watch one of the Robert Sorby videos "Turning a Cherry Goblet" or "Turning a Bud Vase".
The goblet video illustrates the cut that I think John is talking about.
Videos
Re: Need some help
Re: Need some help
Timmy
>Thanks the both of you two for this information, it has helped me.
Re: Need some help
Re: Need some help
RussFairfield
>There are a couple articles on making boxes Wood Central articles section.
Go to www.woodturningonline.com and click on "projects" for a list of other articles on the topic.
Re: Need some help
Brad Vietje
Turning Boxes With Richard Raffan
Brad Vietje
>Both the book and the video are excellent, and if you plan to make a lot of boxes, a good investment.
Safe Spinning,
Brad Vietje
Newbury, VT
