upside down tagines
adrien
>Tagines are Arabic cookware. Inspired by Jimmy Clewes' DVD wherein he makes one a bit larger and a bit thinner. (Great teacher.)
upside down tagines
adrien
Re: upside down tagines
Bill Hale
>OK You got me. How would these be used as cookware ?
Bill in Casa Grande, AZ.
Dave Belser
>I had to go Google Tagines - covered stoneware - to find out what you were talking about! The look like natural edge vases to me. It's funny because I just did about the same thing. I sliced off 8" of a 3' dia log and cut it into wedges and then turned 5 vase forms - two of which could be called success.
What kind of wood did you use? It looks a lot like the Ash that I've been turning.
- Dave
Brad Vietje
>These are real nice, Adrien.
I make quite a few vases like this -- natural edge, and turned on the pith. I'd also like to know what wood, and what sort of success you've had with cracking, etc...
Safe Spinning,
Brad Vietje
Newbury, VT
Skip Beardsley
>Check out a recent issue of Fine Woodworking. Alan Lacer has an article there on turning end grain and some of the things in the article look similar the the objects show here. He goes into detail on how to turn the endgrain without having the checking.
adrien
>Bill, I've sent you a NY Times article on tagines. 'twas a friend to whom I gave one of these oak vases who promptly turned it upside down and called it a "tagine." No, he's not Arabic.
I wouldn't try putting one of these on the stove top.....
adrien
>Dave, they were taking an oak (black, I think) down near where I was working. When I heard the clarion call of the chainsaw I rushed out and one of the guys with the chipper was kind enough to put a few logs in the trunk of my car. I had trouble lifting one out of the trunk and he carried two at a time.
adrien
>Hi Brad. the wood was, I think black oak. Turned green, of course. The bases cracked on the first few, so I ended up soaking them in Danish oil and letting the dry verrry slowly in a parially opened plastic bag, recoating them daily for a few weeks. Those did not crack in the base, though they needed some more sanding after they were fully dry (which often happens with my green bowls�the grain seems to raise up.)
adrien
>Skip, do you have the specific issue of Fine Woodworking? I checked on line and can't find the reference.
Skip Beardsley
>Fww #177 June 2005
Re: Raised grain is what
Allen Neighbors
>you get when you dampen Oak with oil or H2O. That's the way to get a better finish on oak... wet sand, allow to dry, sand again, finer grit... and so on.
I'd still like to know how they use these things as a cooking vessels... I'm scratching my head.
Allen
