We value your privacy.
>I have just collected a number of beech, maple and walnut logs. All were cut to about 1' to 2' in length, and I have wax sealed all the ends. As the pile is currently in my garage, I'm looking for other options. Would it be acceptable to store outside? I thought about placing on a frame, off of the ground, and covering with a few tarps. I could use as needed. Since I'll be turning wet, I'm not concerned about outside moisture (Upstate NY).
When I get time, I'll process into bowl blanks and turning squares, and again wax coat.
I can also place in back of my garage, facing south.
As always, thanks from the group for any recommendations.
>Gary I just store mine on my gravel driveway out in the sun. Not the best place and I lose a moderate amount but it's all free so right now I don't worry about it. I'm planning on building a covered shed out back that has a gravel bottom and shelves. Wood that has been split or at least sized so I can pick it up will go on the shelves. Fresh green logs will go on the gravel. I'm hoping that keeping them out of the sun will reduce the checking and putting them up on shelves will keep the bugs out. Anyone else have opinions on this.
4 concrete blocks and a couple of landscape timbers make a pretty good rack for cut logs. A cover is a good idea to keep the rain and sun off the stack, but throwing a tarp over the whole thing reduces airflow and may lead to stain or spalt. On the other hand, too much airflow can lead to excessive checking, even with the ends coated. Getting the logs processed into blanks is the best way to ensure maximum useful wood and minimum degrade.
>I'm reluctant to store "raw" wood anywhere inside. This is mostly because you risk introducing whatever wood loving bugs contained within to your house and shop. My results storing wood outside varies. I collected a good size stack of branches (largest < 6" dia) that the utility company left when they trimmed our road. I painted the ends and left them stacked on rails in the shade for almost two years. Just recently I got into the pile because I feared that it was all going to waste. Some of it showed spalting - particularly Birch - but I was surprised to find most of it in good shape. At this point I've roughed about half of it into cylinders and painted the ends with Anchorseal. I now have a large box of blank cylinders in my shop.
This last October I collected about 6 large pieces of Maple. I left these standing on end on the ground and covered with a tarp. Again it looked like after 6 months outside covered they were starting to check and I feared that it would all be firewood. I just recently reduced it to turning sized filches and coated the ends - there wasn't a lot of deep checking and no spalting.
I stored a Cherry log in a garbage bag from early spring to late fall, it didn't check but boy is it stained now!
So it all depends on how valuable the wood is to you. As turners I think most of us harvest/collect our own wood so it's free except for our time. Dry slowly, protect the ends. Large logs should be split on the pith to reduce the chance of big checks that run the length of the log. If you keep it too wet it will spalt. Heat your shop with a wood stove and you can burn whatever doesn't work out! If you have something that is rare or exotic (too you) then pay more attention to it.
>As a minimum you should be splitting them in half along the pith, or making a cut on either side of the pith and removing it altogether.
Then store them as Gary has suggested.
The best way I have found to store wood for the longest time with the least amount of degrade is to cut it up into lathe-ready turning blanks and then cover it 100% all over with Anchorseal or wax. Then it can be stored almost anywhere that isn't in the direct sun or so hot that it melts the wax.
>Coating everything with Anchorseal is an excellent move -- I don't usually coat the bark. I mostly agree with what everyone else already wrote, but 3 notes:
1. Walnut is pretty stable, and much less likely to crack than the Beech, which is not. However, if you want to exploit the nice contrast between heartwood and white sapwood in Walnut, the sooner you rough turn it, the better -- sapwood will tend to turn grey/brown after a while. I'd definately split the Beech logs unless you intend to turn something with the pith in it -- if so, sooner will be better.
2. If you intend to turn this stuff green, there is no need to get it up off the ground -- there will be less drying on the ground, and more cracking up on a rack that allows possibly too much air circulation.
3. Keep it out of the sun -- DON'T put it on the south side of the garage, but if at all possible, on the north, in the cool shade. Create shade, if necessary, but remember that a tarp out in the hot sun can create an oven. If you have to use a tarp in the sun to create shade, leave some room for air to circulate -- make the shelter taller than the wood pile.
