Boiling Madrone Bowls
Rick Davenport
>I got a bunch of madrone on Sunday.
And with it some advice to
1 - turn green and thin and let nature take its course
2 - turn green then boil
3 - turn green then microwave
4 - turn green and thick then seal and cross your fingers
I'll probably try a little of all 4
1 and 4 are self explanatory and I have book info on microwave drying.
As far as boiling ..... how hot, how long and what do you do afterwards?
I tried the search function on this site, but obviously didn't do it right as I'm sure this has been discussed ad nauseum.
Could somebody help me out?
Thanks,
Rick
Re: Boiling Madrone Bowls
Here is some info on madrona *LINK*
Dave Smith, Longview, WA
>Richard Dowling asked this via email on 1/3/06.
Q: "I picked up some Madrone in California last week. It's very green. Do you have any experience turning it?"
A: My experience with madrona is that it needs to be turned thinner than the 10% rule. Also, use fresh alcohol and soak the roughed out bowl at least 24 hours. I had some spectacular failures when I left the walls too thick and soaked them in an old solution that had a low percentage of alcohol. Subsequent pieces that were turned thinners and soaked in fresh alcohol had very few problems.
Madrona needs to be turned soon after cutting. It splits every which way you can imagine. It needs to be sealed on all surfaces and kept out of drafts and sunlight. Madrona is also susceptible to blue stain which will develop in the sealed blanks.
Dave Smith
The Dear Abby of alcohol in Longview, WA.
Alcohol Soaking Blog
RussFairfield
>You asked about boiling.
Boiling temperature is the boiling temperature of water - 212F in an open pot 235F in a pressure cooker.
The common rule is to boil the wood for 1-hour per inch of thicknes in an open pot, 1/2 hour per inch of thickness in a pressure cooker.
Put the wood in the cold water, bring it to a boil, keep it boiling for time required, and then let it cool in the water back to room temperature. Now you will have to dry the wood, and use whatever method you choose to slow the drying rate.
Throw a few small pieces of Padauk into the pot if you want to keep some of the ponk color of Madrone.
Molly Winton
>I've emailed you Steven Russell's boiling wood protocol. It's very detailed, and very helpful.
Rick Davenport
>Thanks Dave, Russ and Molly.
It looks like I'm going to be busy for awhile.
Rick
Rick, email me
Molly Winton
>I can't find your dang email address anywhere. I'm assuming the one tagged to your post here is invalid.
Re: Rick, email me
Rick Davenport
>It should work.
Don't know why it wouldn't.
But I'll email you anyway.
Rick
Re: Rick, email me
robo hippy
>Rick,
As one guy in our club said, "Madrone starts to split when you fire up the chainsaw." I like to turn it thin (no more than 5/16) and then let it turn into a potato chip. I had one bowl that finished at 13 inches long by 9 inches wide. I used the LDD soak for it. I like the excentric shapes. It turns wonderfully when green. I have never boiled it, but have heard that the 10% rule works if you boil it. Soap and alcohol do not stop the movement. I usually just shelf dry it. Crotch pieces are more prone to splitting, but if you slow dry it, it usually isn't a problem. You should really see what the burl does as it drys.
robo hippy
Dennis in Southern Oregon
>Rick, you got a lot of good advice; I'll just add one more point. In my experience (and my location) boiled madrone molds badly if it is wrapped after boiling. Doesn't seem to if left open to dry. I am not sure if the alcohol process will inhibit molding or not as I have not tried it with madrone. Dennis
