I made a thin parting tool out of a
Jim K in Trappe PA
>12" rule that I picked up at a flea market for $1.
Re: I made a thin parting tool out of a
eaglesc
>Butterknife from an old set we no longer use.
Planer blades
Ken Grunke from SW WI
>From portable thickness planers--but some of them have just a thin layer of HSS bonded to plain steel. If you see a thin layer of copper just below the widest face, "those are them".
If it looks like solid steel but you're not sure if it's HSS, do a grinder spark test--HSS will have few sparks that are a reddish color, High carbon steel will have lots of thin, bright yellow trails. High carbon is just fine for a parting tool, you only have to be careful when grinding so as not to overheat it and lose the temper.
Industrial hacksaw blades are another good source.
>so was it Brown & Sharpe, Lufkin (sp?), or Starrett? ;)
Leo Van Der Loo
Re: I made a super thin parting tool out of a
Leo Van Der Loo
>regular hacksaw blade for ultra thin parting of miniature boxes and other micro turning stuff.
Have fun and take care
Leo Van Der Loo
Bill Hale
>I use one of the big hacksaw blades from a machine shop. FREE
You have to use a cobalt drill if you want to mount it in a handle.The blade has one hole in the end and you need another for secure bolting.
If you do this be sure to widen cut as you go in or it WILL hang with bad results.
Bill in Casa Grande, AZ
Drywall saw
Mike Brazeau
>I ground the teeth off a drywall saw and shaped the end. It works quite well. Handle comes with it as a bonus.
Mike
Dick Hines
Dick Hines
>I made a parting tool out of saber saw blade. it's only 1/32". It is kind of short but wooks great on minis.
Brad Vietje
Re: Drywall saw
Brad Vietje
>Cool ! I just finished a drywall job, and I had to buy a new drywall saw, since I couldn't find the old one...(musta got lost with John's afro, tiny screws and yellow jumpsuit !). Wouldn't you know that the day after the job was done, the old one turns up ! I think I'll grind the teeth off just to punish it !
Thanks for the laugh,
Brad Vietje
Newbury, VT
