Solid Ended Pens, Pics
Jim Shaver - Oakville, Ontario
>Hello,
I thought I might show some solid ended pens I made today. These are fun, I use a pin chuck and shape the solids as I see my way though some designs.
I�ll call this one my Sunday Masters Pen, today Phil Mickelson won the Masters and as a fellow Leftie Golfer it was a pleasure to see him win. So this green pen is in fashion today
The Lucite is a Chocolate Mint from Pipe Makers Emporium, the hardware used is a platinum Gentlemen�s kit from Craft Supply. The pen is finished with Ablaron and Micromesh, then a plastic swirl remover.
This is a remake of a pen I made awhile ago, it was a double solid end pen but one end met with an accident, so I tried to salvage the pen by using a solid platinum end from a Jr. gentlemen�s kit.
The celluloid is a red crimson from Craft Supply USA, it was finished with Ablaron and Micromesh, then a plastic swirl remover.
These were fun to make, working with pin chucks gives you a real chance to create unique one of a kind pens�..one warning�it�s addictive!
Thanks for viewing,
Take care,
Jim
Re: Solid Ended Pens, Pics
Allen Neighbors
>Jim, your pens are just awesome!
Have you ever seen or used Chittim Wood? A man gave me a 10"dia log about 36"long the other day. It was very old, unprotected for years, and cracked pretty bad. But I saved a chunk big enough for a small bowl. It's gorgeous wood. Let me know.
Allen
>Hi Allan,
Thanks for your kind comments about my pens, I enjoy making them...
I have never tried Chittim, I will indeed get in contact with you, thank you!
Take care,
Jim
Hi Jim
Dominic Greco in Richboro PA
>Jim,
Glad to see thay you've been keeping yourself busy! :>)
I have to say, while I like the "chocolate mint" pen, that the red crimson one is my favorite of the two.
Very cool work!
See ya around,
Dominic
Jim, URL for PiPe Smokers
MountainMan
>Jim!
Great looking pens - so you get any better prices for the acrylic material from Pipe Makers?? Got a URL for them??
Regards
MountainMan
If there is a double post of this message - blame me!! Ha!!
Re: Jim, URL for PiPe Smokers *LINK*
Jim Shaver Oakville, Ont.
>Hi MountainMan,
The lucite that Andrea sells comes in sticks that are 7/8" square and 18" long. The pricing is very good, but lucite is translucent, so you need to paint out the pen kit tubes to mask the look of the brass.
Take care,
Jim
Link To Pipe Makers Emporium
Jeff Taylor
>AMAZING pens (as always!)
You said that you must paint the tubes to keep them from showin through. May I ask what type of paint do you use ?? And then what type of glue do you use ?? I had considered using epoxy and attempting to tint the epoxy with black/white pigment, but have not gotten around to it. I have tried a Sharpie and CA glue, not a success at all .. I twisted the tube right out with no effort.
Thanks for the answer and the inspiration
--jeff
What I do
>Hi Jeff,
Thanks for your kind words about my work.
I also tried the Sharpie and CA glue in colouring tubes, they also failed for me too.
What has worked for me is to use fast drying Krylon Black spray paint, I scuff the tubes first then suspend them on a cut coat hanger wire to paint them. They are dry in under 30 minutes, I use 5 minute epoxy, it�s clear. I coat the tubes and slide them in and let them set up over night. So far I have been very happy with the results and no failures with the tube.
I have also used a product called Blacken-It, it oxidizes the brass and makes the tubes black�.look in the rail way section of your local hobby store for that. I am more sold on the Krylon though.
Hope that helps,
Take care,
Jim
