First aid for Craftsman lathe?
Edward J
>Yeah, an old 12" Craftsman lathe, the kind with the tubular steel bed. Problem is, the tool rest is wiggly. Examined the problem and found that the steel strip running underneath the lenth of the tubular steel bed is riveted on, and the rivets nearest to the headstock are loose. Of course, thats where the most use is, so it's no wonder why the rivets are loose. Tried peening them a bit, but that didn't work. I could try shimming the steel strip with wood chips, but that's just a bandaid solutionm bed.
I guess a more permanent solution would be to remove the bed and tailstock, drill out the rivets and pop in new ones. But if the old rivets failed, so will the new ones. Mmmm...Tap the rivet holes, epoxy the strip on and replace the rivets with screws and lock-tite?
Seems a bit drastic, any suggestions out there?
From old woodworking magazines, I've read reader's suggestions of filling the tubular bed with cement, for weight and rigidty. Anyone try this?
Re: First aid for Craftsman lathe?
ben d.
>Had one of those many years ago and the same happened to me. Drilled and knocked out the rivets and ran a tap in and used taper head screws back in with loctite on them. Was still ok when I replaced the lathe. You may have to grind the head down a bit for the steady rest or the tail stock to slide.
Keith Tompkins
Keith Tompkins
>I have one of those monotube lathes as well.....my wife picked it up at a yard sale. It has the same problem...this affects the alignment of the centers as well. You'll have to drill and tap the tube, and use fasteners with countersunk heads. A temporary solution....swith the tube end for end.
I keep it around as a backup...if my other lathes are tied up..it works just fine.
Allen Neighbors
>I think you should do as you suggested: tap the holes, epoxy the tube, and counter-sink the screws. But as Keith said, the alignment might be a problem, be sure you check that out and get it right first.
I had planned to replace the tubes on my first old Craftsman Lathe with 8' long black Gas Pipe, because I wanted to turn some old porch posts on my old house. However, I bent the shaft first. :o(
Allen
weld it?
Bob Fawcett
>You could drill a hole in the strip just up to the tube and weld the strip to the tube. The heat may warp everything and ruin it.
On second thought, don't weld it, put in the screws as suggested.
Ditch it
Jim Reed @ Tallahassee
>I received a tubular Craftsman lathe from my dad as a gift and used it for many years. I had to ditch it during my last move and later replaced it with a Jet mini. BIGGG difference. The Jet is quieter and has less vibration than the Craftsman. It is a much more enjoyable tool. My advice is to fix this one and sell it to someone who needs a starter lathe. Use the proceeds to buy a better lathe. You will be happier in the long run. Good luck.
Re: weld it?
Edward J
>O.K. thanks for the advice. Bought the lathe with money I earned as a dishwasher way back when I was 16, but it's sat in a garge for almost 25 years...
Funny thing is Canadian Tire had a "special" on a woodworking lathe in last week's flyer. Went down to check it out. Virtually identical, but the headstock had 5 speeds (albeit with a cheapo motor) and a reverse thread to do outboard turning. The bed tube came into 2 pieces, with a ready-rod running through the length, anchored at the head and tail stock. Tool rest was cast, tailstock unchanged. New and improved version? Whole thing came in a box for CDN$ 139.99 and had "made in China" stamped on it...
Really had second thoughts about buying it and using to improve mine, but in the end my wallet won out. Still smarter to save up and buy one with a twin rail bed?
Bill Hale
>WHEN YOU START WITH JUNK THERE IS NO PATCH OR FIX THAT WILL MAKE IT NOT JUNK
E-Bay sell it to someone you don't know like every one else does.
Buy a good lathe and find a new world of turning enjoyment. Quality makes the difference.
Bill in Casa Grande, AZ.
What do you turn?
Phil Joines Krum, Tx
>The Jet mini was on sale at Amazon for $207 after rebates recently. It will turn 10" diameter by about 16" long. 1/2 horse motor, 5 speeds using belt changes. Probably will be on sale again. If you need to turn longer stuf there's a bed extention available for it.
Funny thing is, we have an older Delta Industrial lathe. It probably cost nearly $1000US when new. With the bed extention the mini has most of it's capacity.
