anchorseal homebrew?
Bob Fawcett
>Anyone have a homebrew recipe for green wood sealer?
Thanks
Re: anchorseal homebrew?
Barbara Gill, Remlik VA
>Anchorseal is so reasonable (around $50/5 gal.) and works so well why would you want to go to the trouble?
>I agree with Barbara. I've looked at some homebrews and I've tried a lot of other stuff, like roofing tar, paint, liquid nails, and glue. Anchorseal is just better and easier to use and no trouble to mix up.
john in KS
>Where would be a good place to purchase Anchorseal? I have not looked nor do I have any idea where it would be stocked. Any advice would be appreciated.
Thanks,
John
Re: anchorseal *LINK*
>To buy in small quantities just get it from Woodcraft. They sell it in Gallon size and a galon goes a pretty good ways. To buy in larger quantities see the link below. The best way to get it is to go in with a club or group and buy it in 5 gallons or larger and then pour it off into gallon containers. Don't use milk jugs, they develop leaks really fast, use a better quality container.
https://www.uccoatings.com/
Bob Fawcett
>Found some spalted oak almost in my yard. I cut up some slabs with my chainsaw. I can't buy it locally that I know of, so I hopped there was something I could use till I get some.
Gary Evans Tallassee, TN
>Hi Bob,
If you don't have a Woodcraft or other woodworking store close, you can always seal it with yellow glue.
Gary
>Yup. Either yellow or white gule will work. I have used both. I don't think they are quite as good as anchorseal, but in a pinch I would think either is better than nothing.
Bob Fawcett
>should I thin it or use straight from the bottle?
>Bob,
It really depends on how long you want to try to keep the slabs before you turn them. For longer storage, I wouldn't thin it at all.
Of course, it may also depend on how much you have on hand and how much hassle it is to get more.
Gary
>Bob For temporary storage of about a month or so I use plastic garbage bags. If your worried about mold turn the bag inside out about every week.
>In a pinch, really thick latex paint will do (especially if you have a lot to get rid of).
Ron McKinley
>I've found that three coats of any latex paint works.
Ken Grunke from SW WI
>Every chunk of wood I've had that's been sealed with hot wax has never cracked on me. Anchorseal is good stuff, but paraffin is very cheap--although a bit of a hassle to use.
I had a jug of carpenter's glue that had frozen a couple winters ago, so tried it for end grain sealing. It dried to a chalky white substance, so I figured that wouldn't fly. I applied it again and pressed a piece of shopping bag over it, making sure to work out the air bubbles. This worked quite well.
Old paint has given me mixed results, it needs more than one application. I'd recommend the shopping bag trick for that also, which allows you to flip the piece over so you can seal the other end right away with whatever sealant is used.
