From board to bowl
From board to bowl
From board to bowl
Roy Fek
>Hello everyone,
I've asked this question on another forum and thought I would ask all the very knowledgeable people here:
Anybody have any info on how to take a board, mount it on the lathe,
cut rings, glue up rings and turn it into a bowl?
Is it just as easy as cutting the rings with a parting tool? Is the
angle of the cut critical?
And, are there any tips/tricks for gluing all the rings together at
once, some kind of clamp or press?
I know about the "RingMaster tool/lathe add on", but I'm hoping to do this without it.
If there are any online tutorials, it would be much appreciated!!!
Thanks in advance,
Roy Fek
Re: From board to bowl
Re: From board to bowl *LINK*
Rick Davenport
>A fellow named Jack Wayne did a demo of this technique at a recent Seattle AAW meeting.
He is going to be teaching a class on it at the Seattle Woodcraft store soon.
It's a fairly simple process and does not require exotic tools.
His e-mail address is posted at the Seattle AAW site.
Rick
Seattle AAW
>Roy It's pretty easy but I haven't done it in so long. You have to either calculate the angles and cut carefully, or use a thick board which makes the angles less critical, or cut 2 boards and then stack the rings afterwords. The last project I did like this was about 6 years ago when I built a 3 foot tornado for our club. I used a thin parting tool and got 3 rings out of each layer. I cut up about 6 boards and then stacked the rings to produce a tornado like structure. I didn't re-turn or sand it figuring it would look more like a tornado when it was rough. I dyed it black.
It's pretty easy to figure the angles and thickness. Just draw it first and then measure them. It's much easier to do on the bandsaw, the only difference is you cut the piece of wood in half and then cut out half circles with the table tilted to the proper angle. Then you just glue them all back together later. I believe Micheal Mode is the one teaching this but don't remember for sure. I learned it from an article in Fine Woodworking about 20 years ago or so.
bob davis
>i have made several bowl from boards using the scrollsaw, alittle slower as you have to drill a starting hole for each ring but no joints
adrien
>The one time I tried this, I didn't bother with a starting hole, but just cut in at a 45� slanting angle so that the rings, open in one place, could be glued shut. I did this with a rosewood plank, so the dark wood tended to conceal the glue line.
I didn't like it because the pyramidal shape limited the final shape of the bowl, but it did make for something usable and presentable.
>Just watched the American Workshop guy do a spiral cut band saw bowl on the Woodworking Channel. He took a fifteen inch square piece of 1 3/4" thick piece of wood and set the band saw at 4 degrees. With a sheet metal screw in the center, he wrapped a string around it and drew a spiral by unwinding the string. He cut the spiral down to about a six inch center. He then cut the corners off. Setting it on a "Post" right side up, he sprung it "the wrong way" and slathered glue in the joints. Turning it over, he sprung it down and used spring clamps on the last two inches of the cut, closing it. Basically just bounced the bowl a few times on the post to drive the joints tight. Left it overnight and came back and mounted it on a face plate and turned it. The resolution on the Wood Working Chanel is pretty poor on my computer. (mahogany looks like MDF) I can't imagine that the saw slots closed up well enough to make me proud. If I wanted treen this might work, but for a nice bowl or art, I doubt it. I have to admit that it was impressive to see him just glue it and bang it into shape and leave it to dry. I was Imagining some really Star Wars looking clamp arrangement.
