A55 Smoothing Plane
milwaukee drill question
jared
>remove 1 for email
Hello: I have a Milwaukee drill #0375-1. I ordered the sealed bearings from enco for it. NOw I understand that some of the drills have 3/16 shafts rather than the 1/4" shaft that the bearings are. HOw can I tell before I take mine apart what size the shaft is so I dont waste my time trying to fix something that can not be fixed? By the way my drill has the reversing switch on the top, the opposite side of the trigger switch. Thanks in advance Jared
Re: milwaukee drill question
TDaniel
>that is the late style. I think the bearing you got will fit. Lift the housing off carefully and watch the triggere rod so you know how it goes back together; take a pic if possible.
TD
