Veritas - Innovation in Tools
First attempt at woodburning and color
Dennis in Southern Oregon
>The picture shows two sides of a small vase decorated with a simulated mosaic tile pattern. The "grout" between "tiles" is formed by stippling with a woodburning pen. This small piece (6" H)is intended as a study to see if the concept will work out. Comments? Dennis
Re: First attempt at woodburning and color
>I like the concept (and the vase). However, I think that the size of the "mosaic" is a bit "too much" for the size of the piece. I think that the "mosaic" should be a bit smaller (or the vase a bit larger:)). Or maybe it should go around the piece? I would want to see more wood framing a circular "mosaic" (sort of like a suncatcher) or more the piece covered with the "mosaic". My $0.02.
Rick Allen
>Hi Dennis
Does it work out? Beyond the "makers perspective" what impact does this have on the observer? Is that the sort of impact you, as the maker, are looking for? If you used tile or glass instead would the impact on the observer be different? Would that sort of difference be desirable?
Perhaps a study were one side of the form were done as you have, with burn and dye, and the other side done with tile or glass and grout.
>Dennis What a wonderful idea. I like what you did very much.
Glenn Hodges
>I like new ideas, and I like this one. Thanks for sharing it with us.
Glenn
Georgia
adrien
>FIRST attempt? It's professional. I look forward to seeing what you do when you get to the later ones.
Jennifer@Indy.USA
>Dennis,
These are wonderful! I really like this design. I'm a big fan of mosaic work....my son and I did our entire kitchen back splash in mosaic...so you get a big thumbs up from me on this one. The form of your vase is wonderful too! I think your concept works :)
Nice job!
Jennifer
Rick Davenport
>I like it Dennis.
Especially the panel on the right.
I'd say your idea is going somewhere.
Rick
Mike Rubes, Apex, NC
>Hi Dennis,
I like it a lot! I am just starting to use a burner and like your idea a lot. While I think it is wonderful the way it is, I wonder if a larger/smaller overall size of mosaic tiles would work? The piece on the left seems a little "busy", to me, but the one on the right just works fine. I don't know, maybe it is that the blue flowers seem to get a little lost in the darkness?
Thanks for posting the pic. I definitely think you are on to something and that it is worth following and trying again on other pieces.
As I say, I am still learning to use my wood burner and hope to produce something soon that is worth showing and not just tossed into the "burn" pile!
Thanks for the pics,
Mike
Turning and burning and turning and burning in Apex, NC :)
Molly Winton
>I like this. I want to see how you continue to develop this. Great idea!
Dennis, please contact me...
Ellis Walentine, Host
Lan Brady
>Guess who's work I will be copying this weekend?
Great job Dennis!!!
Lan
>Thanks Jennifer. This work was the reason for my inquiry earlier about prismacolor pens. Actually the color worked out fairly well considering that the wood (madrone) is darker than I would like. For a serious piece, I plan to use some lighter wood or perhaps bleach it first. Dennis
>Thanks for your inputs everyone. I plan to try this out on a larger piece using lighter-colored wood. Dennis
