Glue over a finish?
Glue over a finish?
Glue over a finish?
Bob M
>I'm working on a partially open segmented piece that has one layer of wood overlapping another at 90 degree angles, with some spaces in between the pieces on the top layer. Those spaces will be small enough so that putting on any finish other than a spray after the two layers are together is not practical. I'd like to put a finish on the underlaying layer before glueing the pieces of the top layer to the bottom one, but am concerned about the strength of the bond. I know I could use some sort of spray finish after assembly is complete but would prefer otherwise. I was thinking about an oil or shellac finish.
The glue bond has to be very secure since there will be some turning done after the two layers are joined and there will be some stress (hopefully not too much) on the joints.
Any ideas?
Re: Glue over a finish?
>Bob no one has answered you so I will give it a go. I would use epoxy. scuff the area to be glued with sandpaper and then glue it up. You can wipe away the excess with acetone. It shouldn't hurt the finish but I would run a test to make sure. an epoxy joint will slip like crazy so clamping is a must.
It's highly possible that a yellow glue would work if the the joint is scuffed up before glueing but I just don't know how well it will bond to a finished area. It does stick to my workbench pretty good and it has a finish on it.
