table saw miter sled
>I'm going to redo my table saw miter sled. I particulary want to add an adjustable miter fence. I know I saw plans for a good one in a magazine several years back. I thought it was Wood magazine but I could not find it so far. Does anyone know where there are plans. I have back issues of most of the woodworking magazines.
Re: table saw miter sled
James Fox
>The winter 2004 issue of Workshop Projects had one with a movable miter fence. Also Plans Now has one. www.plansnow.com
James
Keith Tompkins
Keith Tompkins
>Hey John, for what it's worth,I made an adjustable fence on my sled by routing a circular slot in the base, this allows the fence to swing on its pivot point, anywhere from 90 degrees to 45 degrees.. A plastic knob secures the fence. I allowed for micro-adjustments with a threaded lock nut, which will adjust my miter fence a fraction at a time.
Bob Moffett
Bob Moffett
>John,
I think it was in Wood magazine and I am pretty sure that they sell the plans for it on their website.
>Keith That is what I'm looking at. Where did you make the pivot point? I've just been nailing a board down, make a test cut and move it as necessary then nailing it in position. I don't cut a lot of the same angle so just didn't take the time to make it adjustable but now that I have a dryer environment I want to get back into segmented work.
>Bob I thought it was wood also but I can't get their search to work right and I have well over 100 magazines to thumb through. I remember that article because they had a chart you could copy to paste onto your sled to give you the angles.
Tom Stevenson
>Have any of you ever seen plans for a Radial Saw "Sled" for cutting segments? I realize it wouldn't be a sled but I don't remember seeing one.
