We value your privacy.
>I have been asked to make a pair of bookends out of cherry in the shapes of pillars, which I intend to do by gluing two boards together using a paper joint, turning one pillar and then splitting the boards. Does anyone have any experience or advice about the best kind of glue and paper to use for this?
>I made several of these split turnings on commission awhile ago. Big newel posts starting with 5" square stock 48" long. Used kraft paper and yellow glue. To make sure things didn't fly apart, I turned a tenon on each end and fastened hose clamps around them. No way it was going to come apart with those clamps on.
>Peter That's probably a good idea, safety is always good. I've turned a lot of paper joint projects and have only had one come apart. Aparently the paper slows down the glue drying time. I usually wait several hours or overnight before I turn something but this one time I turned it after just one hour and it blew apart.
Lately I've been turning inside out platters. They are held together with a paper joint. I've turned a 16" square platter held together with just a paper joint covering the 3/4" by 6" joint lines and none of them have blow up so far. I am using either newspaper or notebook paper for these joints.
I did a test a few years ago on paper joints to find out if one was better than others. I tried all kinds of paper. The only one that didn't work all that well was water color paper. It just didn't want to split very easily. I didn't find craft paper or paper sacks to be any superior to newspaper, notebook paper, or drawing paper. I even tried colored construction paper. they all work.
If your really nervous about something coming apart simply wrap a layer of filament tape around part of the turning. Turn the other parts and then wrap some tape around the turned area to finish up the turning. This doesn't waste any wood and is very strong.
>There is a tool for this. Split centers are used by patternmakers and on stock where flexing isn't a problem. They allow split turnings to be made without the need for a paper joint. They are a bit spendy for ocasional or one time use. Last time I bought a set for a shop they were around $100.
A few years ago I switched over to hide glue for my furniture and have only had a couple of chances to turn any glued up blanks with the hide glue. In the past I have always used yellow glue and a paper joint for turning the few bowls I have made since I dont have a scroll chuck. I have been wanting to try the hide glue for this because of its easier clean up after perting. Any one have experiance with this?
