This should clear it up
RK in Milw
>In the photo, the tool is held up in front of you with the flat side of the tool facing away from you. Photo A shows the cutter in the CORRECTposition with the cutter on the RIGHT side of the tool. Photo B shows the cutter in the WRONG position with the cutter on the left side of the tool.
When the cutter is on the right, the center of torque goes through the center of the shaft. This way the flat on the tool shaft arrests the torque produced by the cutter. When the cutter is on the left side of the tool, the center of torque is on the left edge of the tool and the flat on the tool shaft can't be as effective at arresting torque.
It was the Sorby Rep who cleared this up for me. He admitted that Sorby's instructions are wrong but he blew me off when I asked him why they don't correct the instructions. As Carole pointed out, the video shows the cutter in the wrong position at first and then in the correct position later. Go figure.
I should also point out that you should cut on the tip of the cutter, not off to the side of the cutter.
Finally, the same instructions apply to the Sorby Multi-Tip tool.
Hope this clears things up for everyone.
Ron
