Bedan tool
Bedan tool
Bedan tool
Hugh Widdup
>Is the a "proper" grind for a bedan tool
Re: Bedan tool
Re: Bedan tool
Allen Neighbors
>Hugh I hope someone responds to this. What's a bedan tool?
Allen
Re: Bedan tool
Re: Bedan tool
Hugh Widdup
>I think it is a small beading tool
Re: Bedan tool
Re: Bedan tool
Jim Shaver Oakville, Ont.
>Hi Hugh,
I have a Bedan tool, at least that is what I was told it was. It's like a narrow square scarper...mine is 1/2" wide. I sharpen it like a scarper with a burr. I use it for sizing on spindle cuts/diameters and also for smaller scraping work.
take care,
Jim
Re: Bedan tool
Re: you don't have to put a burr on it...
>You can if you want to. You can also use it upside down if you are careful. I generally use mine for sizing (like a parting tool). If you are really good (I'm not quite to that level), you can roll beads with it.
Re: Bedan tool
Scott Greaves in Blackfoot Idaho
>There are those who think the Bedan is the most useful turning tool - period! Of course, most of those people are French, where the tool was evidently invented. They really haven't caught on in the US yet, but they can be quite handy if you allow yourself to learn how to use it. I have one, and generally use it to roll beads, but have also used it in a pinch for planing cuts, pretty much the same as a skew.
But in answer to the original question - I don't know! I just sharpen mine the best I can on my grinder.
Scott.
Re: Bedan tool
Re: Bedan tool *LINK*
Mike Brazeau
>Hugh - I made one of of 1/2" square CRS and ground it at quite a large angle, probably about 40 degres or so, about the same as a parting tool. I use it for tennons and have the left edge ground back to make dovetails for mounting on chuck jaws. They are sometimes known as a beading tool. Googled bedan in images at Google and came up with this link at Sorby.
Mike
Sorby Bedan
Re: Bedan tool
The proper way to
Jorge Castaneda
>sharpen a bedan is just like the parting tool, but only on one side, to get a very keen edge, it is very useful, it is tapered fom top to bottom and can be used qith a gizmo as a combo cutting tool caliper to rough spindles to size, I use mine a lot, it is great to size tennons and make cylinders, (I don't use the gizmo) and generally I use it scandalized, that, in sailors lingo means upside down and as they tell you it can be used to roll beads, not too small,
Just experiment with it.
$0,02
Jorge
Re: Bedan tool
Re: Bedan tool
adrien
>that's a picture of a parting or cut off tool, not a bedan. As previously noted. a bedan looks like a thick scraper. and is used upside down, that is with the bevel down. (Zee French do eet zat way)
Re: Bedan tool
Re: Bedan tool
>The drawing is the bedan tool. The tool to the left is a parting tool. The bedan only has one bevel and the sides are tapered. The french use it with the bevel up. Jean Francois Esculon uses it instead of a skew for all of the same reasons except with the Bedan you can turn a bead right next to a shoulder. With a skew, because of the bevel on both sides, to turn a bead with sides that are perpendicular to the turning you must finish the cut with the skew at an angle to the side so the bevel is rubbing. this would be the same with the bedan if you used the bevel down. If you use the bevel up the "bevel" is the flat side of the tool so when you finish a bead the handle is 90 degrees to the work.This is what lets you turn a bead right next to a corner or some other detail. In fact you can turn a small bead on top of a larger bead.
I've never owned a beading tool but they are very similar except the one I saw had straight sides.
Re: Bedan tool
Re: Bedan tool
Bob Edwards
>I use the Bedan a lot and like it very much. Among it's many uses , it will trim off end grain as smooth as any tool I know. It takes some time to get comfortable with it but it is much more forgiving than the skew. Rather than a lot of words here is a site with pictures that may be helpful. My best advice is "Try it, You'll like it"
Re: Bedan tool
OOOps
Bob Edwards
>Forgot the link!!!
http://www.lavieenbois.com/tournage/frame_tour_eng.htm
Re: Bedan tool
Re: Bedan tool
adrien
>Thanks for the correction, John. Well I told you it's used upside down! Bevel up is right.
Re: Bedan tool
Pascal Oudet
Wally Dickerman in Arizona
>I suggest that you contact Pascal Oudet. Pascal is one of the best woodturners in France and he uses a bedan tool. He says that it's used both ways, with the bevel up or down. Pascal's e-mail address is listed in the WoW memberships.
I was using a shop-made bedan tool at least 40 years ago ago, long before I knew what a bedan tool was. I still use one in many ways, but not for spindle turning. I have 4 or 5 in different sizes. A very handy tool.
I grind mine at 30 deg. on the nose, and 20 deg. on both sides.
Wally
Re: Bedan tool
Wally was a mess cook on the ARK-1 too!!!
Dave Smith, Longview, WA
Re: Bedan tool
Better Than Captain of The Head.....
Re: Bedan tool
Re: Pascal Oudet
Pascal Oudet
>Wally, you are too kind ;-)
I have some pictures about the bedan here:
www.lavieenbois.com/tournage/bedane_eng.htm.
It's a cutting tool, not a scraping one. so sharpen it like you would do with a skew, but with just one bevel.
bevel up or down as you wish, but down is easier.
in addition to what is shown on the web page, as someone mentionned, it works wonder for cutting end grain in spindle turning (for example for cleaning the top or bottom of a tall box with grain parallel to the lathe ways): with its trapezoidal shape, if you lay it flat on its side, on the toolrest (parallel to the ways), the edge is oriented in a such way it cuts end grain very cleanly, and it's very stable so there's no risk of skidding to the left or to the right. (ok, a picture would be helpful there. I'll see if I can take one)
Pascal
Re: Bedan tool
Re: Pascal Oudet
Hugh Widdup
>Holly cow, now I have another tool to master
I had picked up a tool on the weekend that the fellow said was a bedan, but it was not, from what I've seen here.
Now I will have to get/make one.
Thanks for the input.
Re: Bedan tool
Re: Bedan tool
Hugh Widdup
>Mike this may make a good demonstration for our guild.
Re: Bedan tool
Elephants and Camels as passengers!!
