A55 Smoothing Plane
CA glue stain
CA glue stain
CA glue stain
Carole Valentine
>I use a coat of wax across hairline cracks that I am going to stabilize with CA. Normally this does a pretty good job of preventing the wicking/staining on surrounding wood. However, on one piece the wood was soft enough that the glue wicked all the way through and out a considerable distance from the crack. This stain still shows after finish turning and sanding. Is there anyway to get rid of it? Thought about trying acetone, but figured I would ask before I possibly make it worse than it already is. My gut tells me that I am stuck with it. :(
Re: CA glue stain
Re: CA glue stain
>Carole there's no way that I know of short of hiding it by doing something else to the wood such as coloring, burning, airbrushing etc. Maybe someone else will have a solution. I know that sometimes we see things that other people won't because we know it's there. Try putting some finish on it and see what it looks like. You can always remove that finish if necessary.
Re: CA glue stain
Re: NOPE
RussFairfield
>You are stuck with it forever. There is no way to hide it other than coating then rest of the piece with CA glue; and sometimes that doesn't work either.
The only way I know of to remove the stain is sand it away with 60-grit, or taking a couple light cuts on the piece with a turning tool. Fortunately, it usually isn't very deep.
Or you can wait. They do tend to disappear as the wood turns darker with age. You can speed that process with a weak solution of lye (drain cleaner) and water.
Re: CA glue stain
Re: NOPE
Carole Valentine
>Thanks Russ and John. I suspected as much. No sanding this one out. It goes all the way through to the inside. It's not that big, but I notice it. Neither my Mom nor my neighbor could see it though. I guess because they don't what know they are looking for.
Re: CA glue stain
Re: CA glue stain
georgetroy
>I have posted about this before. Carole you have the means at hand to reduce CA glue staining. You need to sand then seal with lacquer before you put on super glue. You can also apply one coat of Waterlox to make sure the stain does not spread. The lacquer and/or Waterlox must be dry, otherwise it will be white. This is what I do and it works for me. It's the same wet or dry wood. GT
Re: CA glue stain
Re: CA glue stain
Carole Valentine
>George,
I have used your method before and it does work, but this glue was applied to cracks a while ago, before the blank was ever put on the lathe. It apparently went inches into the wood below the sealant and wicked outwards from the crack. I kept thinking when I was turning it that I would get past it at any time, but it never happened. I think if the wood had not been heavily spalted, I probably wouldn't have had the problem. Live and learn!
Re: CA glue stain
this works for me...
TDaniel
>If you can put the piece back on the lathe then wet-sand it with Watco oil starting with whatever grit you need to get rid of any marks and then sand to about 800 or 1000 with the oil. then let sit for about 15 minutes and then wipe dry. Usually the CA will disappear. You must sand the gloss off the CA (break the surface). Try it, I think it will work.
TD
Re: CA glue stain
Re: NOPE
Peter Teubel
>As one of my friend often says, "Never underestimate the power of black paint."
