Opinions please?
Carole Valentine
>Thinking that maybe I need tomake the collar bigger. Does it look too small to you guys in relation to the size of the vessel?
Opinions please?
Carole Valentine
Re: Opinions please?
Keith Tompkins
>HI Carole...No, it's just right!(just my opinion). However, don't be afraid to play with the size of the opening in the collar. I think the collar would look better with a bigger opening. I also like to undercut my collars, rather that a straight 90 degree shoulder. Nice shape, and beautiful piece of wood....
Gil Jones
>My overall opinion is that you have become very good at hollow forms.
I have never made a collar, but if you felt the need to make it larger, I would say to flare (taper) the outer edge step so it is less dramatic. It looks OK as is, but is maybe a bit abrupt.
Wally Dickerman in Arizona
>Carole, it's difficult to see the shape of the collar against that dark background. Have you ever thought of making a bead for a collar?
Wally
Carole Valentine
>Thanks, Folks. I'll try another collar with a larger opening and modified base. Wally, yes, I have thought about a bead because I have seen them on some of your things before. Did I ever say you were not an influence? Well I lied! ;) I have not tried the bead yet because I have a looog ways to go when it comes to cutting good ones. I keep trying and trying but they always look like junk. I need to come to AZ and take a lesson! And maybe steal your magic beading tool.
Curt Fuller
>There are several ways you could change that collar. But I think it would only be different, not necessarily better. I like it very much as is.
Philip F Duffy
>Carol, The collar seems to be sitting above the lovely form. Is that true? Philip
Carole Valentine
>Philip, no it's sitting flush, but I think the edge is too thick and that is what makes it look like that. Going to experiment with another one today, but I will probably use ebonized walnut or holly. Blackwood is too expensive to experiment with.
Keith, the small opening was pure laziness on my part...I have a 1/2" drill that has a #2MT which is so easy just to slap into the TS rather than digging out the drill chuck (which must be buried somewhere on my bench) and I use it on all my small forms. You're right - I think this larger one calls for a larger opening.
Keith Tompkins
>CArole, I'm not sure what technique you use to make your collars, but here's what I do...maybe it will help. I finish my hollow form, true up the hole, then glue in the collar. I finish turn the collar as part of the form, following the contour of the vessel. I can see instantly any changes I may want to make....Once I have a hole in the collar, it's easy to enlarge it with turning tools, or add accents. East to refine the collar that way, and usually doen't appear as an afterthought.
Curtis TX
>I think the piece looks great. I really admire your work. I learn a lot from the photos you post.
I know my eye is not fully developed to rate forms but it looks great to me.
Carole Valentine
>Keith, I know that is probably a better way to do it. I'm just not confident enough at turning collars yet to glue the thing in place first! LOL
