John Jordan's New Scraping Tool
Barbara Gill, Remlik VA
>I have read several positive reviews about this tool but I have not read any helpful hints about using it. Has anyone else bought this tool? If you can, drop by the chat room tonight around 8:00 or after. If not, maybe you can respond to this thread.
Re: John Jordan's New Scraping Tool
>Barbara I'll try to be there tonight. If I can't I write something up here. I'm liking it more each day.
Re: What new John Jordan tool?
JamieDonaldson
GaryG in MD
>Jamie, It's a heavy, double-ended shear scraper. John Lucas posted a pic of it a few months ago (see Archives). ...Gary
>Here it is Jamie. It's the same scraper he's been using but he's made a really nice aluminum handle for it. It cut's really cleanly. If you use if flat on the tool rest it's very aggresive. If you use is in shear cutting mode it cut's very clean. I've never been able to use a shear scraper on my inside-out turnings until I got this. It's double ended with the opposite angle on the other end so you can shear scrape hollow vessels in both directions.
Carole Valentine
>Looks rather uncomfortable to hold. Is it?
Sorry About the Confusion
>I must have missed some of the original posts. I read a review on another forum which gave me the impression the tool was new.
Re: Sorry About the Confusion
Gary Evans Tallassee, TN
>Hi Barbara,
John Jordan's scraper is a new old tool. He told me that he has used a similar scraper for years with a wooden handle. The one he is selling is the production version with an aluminum handle. The first time I saw them was at the FL show in Jan. John Lucas posted his impressions a few weeks ago after he got his.
My understanding is that John Jordan uses it primarily on a 45 degree angle, with a light pull cut. This is how he slicks up the surface before sanding.
Gary
Re:Its not new, just ......
JamieDonaldson
>....slightly modified. I learned that trick from JJ about 15 yrs. ago, and have been using 2 old diagonal ground scrapers as he used to do.
>No it is quite easy to hold. Mostly because the handle is large enough to grip easily although you really don't have to grip it, just hold it gently. I'll have it with me at TD's so you can try it out.
Dave Peebles Lyons, Ohio!
>And I believe John learned it from Del a few years before. I do use it all the time. It works great for me. But mine is an old Craftsman carbon steel scraper. :) I can't remember if I saw it first at John's place, or on Del's video. But it doesn't really matter. It is a wonderful way to reduce the sanding process. And anything that can do that is great!
Dave
Al Stirt too
tek-Brunswick, Ohio
>Al Stirt showed us the same thing at a demo. I have one made out of carbon steel and it works for me also. John Jordons is made out of one of the new high tech. alloys, Thus it costs a he** of a lot more than our home made ones. Of course John's should hold its edge a lot longer and it has a bevel on each end so it is like two tools in one.
Tom
Brad Vietje
Brad Vietje
>John,
How does this compare to a light shear scrape with a skew ? I don't try to do any major re-shaping with the delicate skew edge, but it seems to work pretty well as a light shear scraper.
Any thoughts on this ?
Safe Spinning,
Brad Vietje
Newbury, VT
