Time to upgrade?
Time to upgrade?
Time to upgrade?
Jim K in Trappe PA
>About two years ago I installed an old Pentium II processor on my 1994 Delta variable speed lathe. It worked fine (except for some initial heat buildup, which I solved by upgrading the heat sink to the one you can see behind the top of the processor). Recently when I began experiencing some abnormal shutdowns. I only have 128K of memory, and think I may need more, but I have heard that Pentium II�s reach a max where memory helps at around 256K.
This leaves me with several options � upgrade the processor, and then add memory, upgrade the lathe, or perhaps daisy chain two Pentium II�s.
Anyone else run into this?
Thanks!
Jim
BTW � I am also interested in switching from Win 98 to Linux. Any thoughts?
Re: Time to upgrade?
John Veerkamp
>Instead if Linux, how about going to Linus?
Dave Belser
>Slap a penguin on that sucker! Linux works great on old hardware.
Brian Hahn in SW Wisconsin
>My old 486 and DOS-5 still work fine. But I've got to repack the drive bearings pretty soon!!
adrien
>Try a new Macintosh. You should get markedly improved performance
Re: This is April 1st I hope?
JamieDonaldson
Vicmarc.fan
>As clean as everything is in your picture you could use anything. Maybe you could get an old fortran processor from IBM. They ran on 14K.
Ron
George Balock
George Balock
>Jim,
I've heard of some incompatabilities between the Pentium and Deltas. Perhaps going with an AMD instead will help.
George
Re: Time to upgrade? Yes!!
Ron in Drums PA
>I installed a P4, what I difference!!!
I'm in the process of connecting a keyboard. It will be used to assit in the new program I demoed called "WoodShapeMaster". You can dial in any shape you want and get it perfect every time. Not only that but you can program different speeds for each type of wood that you turn.
Later next year, a laser cutting tool will be released for turners and WoodShapeMaster as a plug-in all set to be released and the same time. WSM will power this tool for both shapes and depth of cut. And the best thing is, NO TOOL MARKS. The finish is equal to sanding to 600 grit. Truely amazing combo.
Re: Time to upgrade? PLEASE BE CAREFUL
Chuck Ludwigsen
>Please be careful, Pentium processors are very good pieces of equipment, especially when combined with old Delta lathes. However, most of them are run the Windows version of WoodShapeMaster. The operating system can become unstable and requires an immediate shutdown and resart.
When you combine this with sharp bladed tools and spinning wood, it gives a WHOLE new meaning to "Blue Screen of DEATH".
Gary Ljostad
>Jim that lathe will run much better on an AMD Athlon, and you should have at least 1gig ram.
Jim K in Trappe PA
>Thanks for the suggestion. I am looking into a lot of options including the AMD BMF chip. I hear it is a little bigger though.
Jim K
RTwo steps ahead of you.
Jim K in Trappe PA
>Thanks for the concern. Since last spring I have been using the Sherwood Ketchmaster wireless gouges (FCC 104.g protocol) which have improved the safety factor dramatically by eliminating cables which used to always wrap around the spindle - yikes!. This techie stuff has really simplified things for me in so many ways.
Larry Winton
>Your best bet is to upgrade the processor to one of Intel's new P4 chips for the hyper-threading capability, especially if you are doing threaded lids.
Mac
>Next step for you is WI FI.......all my lathes are networked....I can turn green wood from the airport....with Go To MY PC......
Re: RTwo steps ahead of you.
Ron in Drums PA
>If you are going wireless, you should get the AirCard� which operates on both 850 and 1900 MHz and is backwards compatible to UMTS/EDGE/GPRS/GSM.
With data rates up to 1.8Mbps downlink and 384kbps uplink you won't be diappointed.
Dan in the NW
>Actually, if he waits until next year he can by=pass the dual-threaded processors and go straight to a quad-threaded processor. The early test results in the labs show some amazing results. Imagine being able to cut on 4 axis' at once. There is a rumor floating around that they hit a rate of 500 croquet balls a minute or two TDaniels knock-offs a day.
Here are the specs on the lab machine: 1 quad-threaded AMD 6000+, 4 gb RAM, NVidia 8100Turbo GT, 1 terrabyte hard disk, Windows Vista Enterprise Beta, 1200 watt power supply all attached to a Jet 1210VS mini-lathe. (I heard any bigger a lathe and you had to increase the memory x4.)
Dan
Re: And don't forget that ...
JamieDonaldson
>.... in order to shut it down you have to press the START button!!!
