Vibration problem
Vibration problem
Vibration problem
Keith I - East Tn
>Hi folks, I bought a new Delta 1440 a year or so ago and am using a standard NOVA chuck. Problem is that it seems like I have always gotten some vibration evan after trueing up a blank and it's getting worse. Or mabey I'm just getting more sensitive to it :) Is there an easy way to identify the culprit?
Re: Vibration problem
my guess is....
TDaniel
>the pulleys. I think you have the varialbe pulleys? If so try cleaning and lubricating them. After this run the lathe without a chuck on it. If it is smooth put the chuck on and run it again. You should be able to isolate what is causing the vibration.
Re: my guess is....
Pete in Holland, MI
>Might be the drive belt. Unplug the machine then turn rotate the belt, feeling it's pulley contact surface. The Reeves Drive pulleys are rough on belts when you stall your turning.
Steve in NC
>Keith
There have been many threads on this site about problems with the Reeves drive. Do a search and you will get lots of advice.
If you are still under warrenty period, give Delta Tech support a call and have them send you a new pulley set, belt, spring and key. They shipped my parts at no cost and this helped greatly on my lathe.
I have found that keeping the motor shaft clean and lubricated, (I use powered graphite) has also helped.
Good Luck
Steve
Thanks much!
Keith I - East Tn
>I had a feeling it might be somthing along those lines.
