Re: Best method for turning platters and plates
Rick Allen
>When I was first starting out, less than 2 months into my turning life, I used a 8" disc trued up on a 4" faceplate with double face tape to turn a 24" Zebrawood table top and 18" shelf. It was a swivel head lathe so there was no tailstock to help. The top came off the tape twice but I ended up with a piecrust table. At that point I became a fan of double face tape.
Now I have a bigger swing lathe. I generaly start a plate between a Stronghold with #3 jaws and the tailstock. The jaws of the chuck drive the platter blank.
After the blank is made round I make a trueing pass across the tailstock side. In the middle of the tailstock side I cut a shallow tennon.
Remount the stock in the chuck, with the tailstock for support true up the tailstock side. At this point I decide which side will be the top and which will be the bottom.
I turn and finish the rim area.
Depending on which side is the top I turn the rim/body interface with the top side faceing the tailstock. (I may need to have turned a shallow recess if I fiped the plate)
Make a few passes across the face to extablish the slope to the body of the platter.
Back off the tailstock and finish up the body of the platter.
Sand and apply the finish of choice to the top and rim portion of the underside of the platter.
Mount the platter in cole jaws and finish turning the bottom. Sand and finish the bottom.
Wait a couple of days, then buff it all.
This works on platters up to 19". Most of my platters are between 14" and 18".
Good luck
Richard
