CA glue question
CA glue question
ebd
CA glue question
ebd
>Can CA glue be used while the wood is still wet/green?
I have rough turned some green mesquite and there are two cracks where I want the rim. I got some thick CA but no indication if wood needs to be dry.
Re: CA glue question
>CA works well on wet wood.
Carole Valentine
>Yep. You may see some smoke because the moisture acts as an accelerator. I use it on green wood all the time.
georgetroy
>For me CA on wet wood where I have cracks that I need to be filled or repair is a must. It's not unusal for me to make a repair with Corian crushed material. Most of the time I will bring almost to a finish sand, apply lacquer or sanding sealer before Super Glue is applied. Super glue will stain unless you seal before using. GT
RussFairfield
>Just one caution about using CA glue to repair wet wood. The CA is hard and has no elasticity. That means that the wood can pull away from the CA glue as it dries. Other than that, no probloem.
Bill Hale
>CA cures with air and moisture. The wet acts as an accelerator. I generaly put in thin so it goes to the bottom of the crack and then heaverier to close off the outer end.
Bill in Casa Grande, AZ.,
ebd
Re: CA glue question - Thanks to all!!!
ebd
>Thank all of you for your responses. They are most helpful. I'm going to try it out this weekend.
