Cocobolo (sp) problems??
Allen Neighbors
>Would someone be kind enough to explain some of the remarks I've heard recently about Cocabolo (sp) Wood? I think I'm getting the idea that some are allergic to it? Is that it?
I've been turning for two days on a small hollowform...(had to stop twice to make more tools..) and so far haven't had any trouble with it, except that it popped loose from the poplar waste block it was glued to.
Just help me to be aware of the hazards involved in this beautiful wood. Thanks, in advance.
Allen
Re: Cocobolo (sp) problems??
Ron in Drums PA
>I was never sure if it was spelled cocobolo or cocobola.
Any way, Russ once described it this way, "There are two kinds of people in this world, those that are allergic to cocobolo and those that will be."
Re: Russ... You out there?
Allen Neighbors
>That's one of the posts I was referring to... I wonder what the allergic symptoms turned out to be??? Was it a physical allergy to the wood dust, or a mental allergy to working with it, for some reason.
I've been careful to have the exhaust fans going, and the other fan blowing across the piece in question... just wondering if that's enough.
Allen
Re: BTW, Thanks, Ron.
Allen Neighbors
Re: Cocobolo seems to cause....
JamieDonaldson
>... allergic reactions in a number of woodworkers, and like any dust hazard you should keep breathing exposure to a minimum. I have been turning it for years with no problem, and its a favorite wood when I can afford it, but I also have a good dust collection system.
Verne
>Being one of those who has a severe allergy to Rosewoods in general and Cocobolo in particular, I can tell you that it is both a respiratory allergy and a topical/contact one. The dust generated by turning the wood can cause a reaction by just settling on the skin. If you are one of those who develope a sensitivity, this isn't an allergy to mess with as it can make you quite miserable and can in cases of extreme sensitivity generate anaphylactic shock. One tends to develope a minor rash type of reaction to the dust initially, but once sensitivity is established, continuing, future exposure tends to multiply each time in severity.
I still turn the wood on occasion, but take considerable precautions. I wear Tyvek overalls, rubber gloves and a Tritan respitator (Tritan's shroud covers all exposed skin above the shoulders). BTW, I am not allergic to anything else . . . that I know of.
Gary Evans Tallassee, TN
>Hi Allen,
There are a number of woods that people have shown a sensitivity to. Cocobolo is one.
The easy way to find out if you are sensitive is to take a little sawdust, wet it, and put it under a bandaid on the inside of your wrist or in the crook of your arm. Check in 24 hrs. If you don't have a bunch of aggravated tissue under there, then you are probably O.K. for the moment.
Gary
Re: Cocobolo problems??
Barry Turner
>The last time I turned cocobolo I had a reaction. I had to go to my doctor and get a shot of cortizone which cleared it up soon enough. I didn't have a severe anaphylactic reaction with difficulty breathing and constriction of airways as can sometimes occur with alllergic reactions.
It was more of a contact dermatitis (a rash) that manifested itself on the insides of both elbows. There was an itch and redness that lasted for several days. On the insides of the elbows, skin contacts skin with a layer cocobolo dust in between. The reaction was exacerbated by the fact that it was summer, my shop has no AC and I was sweating quite a bit.
My suggestions: Avoid breathing the dust by wearing a good mask at all times. Dust collection would certainly help. In the absence of a dust collections system, a pedestal fan aimed so as to blow the dust away from you can help. Try to turn cocobolo during cooler weather and wear long sleeves to keep the dust off your skin.
If you experience any signs of difficulty in breathing, stop turning and get to a doctor or the ER immediately.
GaryG in MD
>Allen,
It's not a surprise that it popped off your waste block. It's very oily and must be glued with special procedures. You can get tons of info if you Google "gluing cocobolo". A good article, overall, on cocobolo can be found at
www.woodmagazine.com/wood/story.jhtml?storyid=/templatedata/wood/story/data/cocobolo.xml
You might also want to read more about "sensitizers", because this is one of the classics, as you have read from other responders.
Have fun with it,
Gary
not a good wood for tool handles
TDaniel
>This is not a wood that you would want to have in your hands for long periods of time.
Re: Thanks for the answers
Allen Neighbors
>Thanks to all of you for your posts. I finished the little HF this afternoon. When I started sanding on the bottom, I had turned off my fan, and smelled the wood (it smells nice)it reminded me to turn the fan back on. Just that one whiff or two made me breathe heavier, later. I'm glad I had read some of your posts before I went back out to the shop. I put my face shield on and turned on the fans again before I finished it. I'm okay now, so I guess no harm done. This is my only piece of Cocobolo. I'll post a pic of it later. Thanks again, all.
Allen
