Central Machinery Wood Lathes
Thad
>I found via google a thread posted back on 2004 regarding these lathes, but the link said the thread was unavailable (purged I suspect). Does anyone have any input on the quality or shortcomings of these lathes?
Re: Central Machinery Wood Lathes
Thad
>This is a 14" x 40" model, not the smaller one referred to in the archives.
>I think that the 14" x 40" is a bit light at 88 lbs. I think that the ways look like hollow steel tubing from the diagram in the online manual. I think that at 1/2 hp, the motor is a bit undersized. It all depends on what you want to turn. You might look at some older used lathes. My $0.02.
Jason Clark
>I went with the 12 X 36 (http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=34706) over the 14 X 40 (http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=45276) for my first lathe. The 12 X 36 is essentially a Jet 1236 knockoff or factory 2nd and has a cast iron bed, rotating headstock, reeves drive speed adjustment (with a much wider speed selection), and weighs just under 100 pounds more.
Both have the laughable sheet metal stand and you can set aside the "tool rest arm" immediately. The 3/4 HP is severly underpowered for a 12" swing, I can't imagine that the 1/2 HP on the 14" swing can be any better.
You can find the 12X36 on sale for $179-199 on a regular basis.
You get what you pay for
georgetroy
Rick Davenport
>For what it's worth.......
I buy a lot of stuff at Harbor Freight.
But I would never buy anything from them that falls under the heading of precision machinery.
Rick
Nathan Pettigrew
>I have the 37406 and like Jason says, it is a copy of the Jet lathe. It is pretty solid and I haven't had any problems with vibration. I have the stand mounted to a double thick layer of 3/4 particle board with casters. This makes it portable and brings it up to a better height for me.
The only problems I've heard about this lathe is belt breakage. But that is an easy and cheap fix.
I would stay away from the tube bed lathes though. Those look VERY cheap.
Hope this helps,
Nathan
Bob Fawcett
>Some of the best advice I got from this forum was to buy a Jet mini. You should be able to find it for $279 or less. You can add a bed extension for under $100. You end up with a 10 x 40.
You also have a good lathe that you can resell for most of what you paid.
bigbillh
>Do you like the 34706 lathe? Does it do a good job? Is there vibration to deal with? If so would more weight in the stand reduce it?
After having used it for awhile would you recommend it or not?
Thanks,
Bill
Russ Fairfield
>My advice is to go to the nearest Woodcraft store (or maybe the catalog or website). They are having a sale on the Jet Mini with the step pulley drive and a Nova chuck for $269. That is a savings of more than $100. It may be smaller, but you will have a real lathe with a bigger motor that will do everything better than either the 12" or 14" from Harbor Freight. You will not be disappointed.
