Flapper Wheel Extension
Barbara Gill, Remlik VA
>I just ordered some flapper wheels that are 1" and 1 1/2". The problem is that they have a 1/4" shaft. Does anyone know where I can find an extension shaft to hold the 1/4" shaft and fit into a regular drill? I plan on sanding the inside of hollow forms with them.
I am not into making my own stuff. It would cost more in supplies and time developing new skills than it is worth to me.
Re: Flapper Wheel Extension
Gary Evans Tallassee, TN
>Hi Barb,
Usually you can find a drill bit extension wherever you find drill bits, particularly if they have spade bits. They are usually designed for the 1/4" shaft that you find on a spade bit.
Gary
George Van in WI
>Barb, if you use the spade bit extension you may want to put a small diameter PVC, CPVC pipe over the shaft so you can hold the drill and the pipe covered shaft for better control.
georgetroy
>You can find most bit extensions at your local lumber Co or Ace is the place. You might be disappointed in the performance of the 1" flapper wheel. I got mine from Klingspor's and it was much too stiff. GT
Gary in Zirconia, NC
>I put a little wax on the shaft and just hang on to the shaft. I like it better then the pipe, which I've tried.
Bill Hale
>Barbara
Any of the big box stores or Ace should have a spade drill bit extension. Be sure to slip a sleeve over it so you can hold on to it. Any type of sleeve will work eg. pvc.
Good turning and be safe
Bill in Casa Grande, AZ.
Thanks Guys
>I am going to Richmond tomorrow and will pick up an extension.
Re: Be sure to get the right type of extension.
Al Crandall (NE of Indy)
>Barb, you will fine two types of extensions. One has a 1/4" hole with set screws in the side. This is the one you want. Another type has a hex hole in the end with a ball detent keeper. You don't want one of those. I use a 12" extension in a drill a lot. I have never found it necessary to use a sleeve or lubrication or anything else to control the shaft. The round smooth metal shaft cannot grab your hand, and it will not get hot in your hand if you are holding it with the right pressure and are not turning it at too many rpm.
>Thanks Al, I will keep that in mind.
I fond a neat way to do this!
Doug Trembath
>Barb, Gary, et al...
I took a piece of hard, dense wood, (Carob in this case) and turned a good size to fit my hand, then drilled a hole just larger than the bit extension, and use it to add control. I can see how a sleeve would work, but this affords excellent control, and feels good in the hand. Sorry no pics, but I'm sure you get the idea.
Doug Trembath
Studio in the Woods
Neat Idea.
