steel Lathe
steel Lathe
steel Lathe
graeme
>Can I use a lathe designed to turn steel for turning timber. Any pros/ cons? Ive got a wonderful steel lathe but my engineering friend shudders whenever I mention the idea of using timber on it.
Re: steel Lathe
Re: steel Lathe
Ken Grunke from SW WI
>One big point I've heard many times is that a metal lathe used for wood may not get enough lubrication in some parts. When machining metal, a cutting oil is generally used and that keeps the slides and carriage lubricated. Wood dust will soak that up and those parts will wear faster unless you lubricate the various sliding and rotating parts,
Then you risk oil smears on a nice woodturning. I've turned wood on my machinist lathe when some precision is required (making chucks, for example), but it's not very convenient for freehand turning.
Re: steel Lathe
Re: steel Lathe
Phil Joines Krum, Texas
>At one time some "home" metal lathes came with a banjo and tool rest for turning wood. I have one made around 1930.
If you have flat top ways the easiest way would be to find a banjo from one of the lathes in production now. If the ways are V top you probably need to make an adapter.
Be sure to clean off ALL the shavings and oil the ways after each use.
Re: steel Lathe
Re: steel Lathe
RobinCorell
>One of the shops I worked in had a nice old engine lathe that we used for wood patterns. When we needed to turn freehand we would use a rather large boring bar with out a bit . The obvious short comming to this is that if you get a bad catch something is going to give and it won't be the tool post.
Robin Corell
Re: steel Lathe
Brad Vietje
Re: steel Lathe
Brad Vietje
>I've turned wood on a couple of metal lathes, or metal to wood converstions, and the thing I remember most is that the cross feed gets in the way a lot. It would work better with a new banjo/toolrest combination that will allow better tool access to the piece. They are very stable due to the high mass, but I like to use many of my turning tools with a pretty steep angle (tool handle down, not level), and all that bulk does get in the way.
Safe spinning,
Brad Vietje
Newbury, VT
