A55 Smoothing Plane
what would you make?
Derek in Dundas
>OK I have a 1/2"x21" piece of drill rod. Being a new turner I have some room for new tools. I picked this up from a friend he wasn't using it so now I have it. I thought of some ideas likeabout making a Hollow scraper or round Skew and another tool... just not sure.
I guess my question is what tool or tools would you consider making?
Re: what would you make?
>1/2" is too narrow to make a very deep hollowing tool. About 8" is max for that size but you could make 2. A straight one and a bent one if you have a way to heat them up. You can insert some 3/16" HSS cutting tips which I will furnish if you'll e-mail me. I think I have a piece or two left. You need about 2" or so inserted in the handle.
1/2" round skew is OK but it's actually too thick. The thickness of the tools gets in the way when turning larger beads that are side by side or a curves surface that comes up into a straight surface. That's a louse description but I've played with round skews and 3/8" is about as thick as I like on a round skew. I think that's why they are usually flat.
Ken Grunke from SW WI
>I agree with John, I don't use my 1/2" round skew since making a 3/8" one.
I'd cut the piece on two or three pieces, and make a skewchigouge, a pyramid tool, and maybe a hook tool. The hook tool would be more work, they're usually made from 3/8" stock if you forge them the way Alan Lacer does.
If you have a handle with a setscrew socket, you could make double-ended tools.
Jorge Castaneda
>Derek,
You can make a handle out of some wood plus a short lenght of galvanized pipe and a set screw, and your rod can be made into 2 or 3 (short) cutters, a hook tool, essentially a gauge, a round scrapper or a round skew, drill rod is cheap, so you can just get more, I made some recently pics soon.
>Thanks for the response, exactly what I was looking for. Experience and knowledge. I really liked your feedback and input.
Keep it up, as I am sure as a newbie I will keep up the questions.
Thanks
