question for desert turners of mesquite
ken chase
>Thought it would be fun to work on a mesquite root that a neighbor had removed from his yard. Put a new chain on my chainsaw and could not cut this darn thing. Is the root much harder than the rest of the tree?
Should I give up?
Thanks
Re: question for desert turners of mesquite
Re: Mesquite root shouldn't
Allen Neighbors
>be that much harder than the tree itself. I've cut a bunch of Mesquite. When trying to cut the roots of a tree, it's always best to wash the dirt away with strong spray of water, and allow to air dry before cutting. Did you remove all the dirt? That will dull a chain quicker than cutting a piece of iron. The only other thing I can think of is maybe the tree root grew around something metal, or a rock.
Hope this helps.
Allen
Dick Hines
Dick Hines
>I am not beenin a wise a.. ken but you put your chain on so it is in the right direction? I have seen it done. It's easy to do when you get rushed.
chain saw
tek-Brunswick, Ohio
>It sure runs smooth with the chain on in the wrong direction, but it doesn't cut worth a D##n. It happened to a, erh, a, ummm, a friend. Yeah a friend. I won't even go into what happens if you put the oil and the gas in the wrong tanks. No, it doesn't pay to hurry with a chainsaw.
Tom
Roger
>My neighbor tried to saw with a chain on backwards and unsawed a half cord of firewood before he realized what was wrong:)
Re:This thread is starting to.....
JamieDonaldson
>.... sound like the story about correcting that last bad cut and putting the wood back on by running the lathe in reverse!
RussFairfield
>.... or about the guy who cut 3 cords of wood before somebody showed him what the starter cord was for.
Roger
>Or the fellow whose tractor got stuck in reverse and before he could get it stopped he had unplowed three acres.
Re:Thanks. Enjoyed your comments
ken chase
