longworth chuck
longworth chuck
longworth chuck
jared
>remove 1 for email
Hello: This past week I finished making the longworth chuck that was written up in Woodturning Design this winter. I followed the instructions closely and it all worked out like it was supposed to. I was amazed at how easily the two plywood discs rotate against each other and how smoothly the size changed. I like making things like this that require a little geometry and following directions closely. I used it to turn the bottom off one bowl that was probably 11 inches in diameter. I had previously used a donut chuck and would have to say that I preferred the longworth. It gives you better access to shaping and sanding the whole bottom of the bowl and I particularly like the fact that there isnt a plywood disc whizzing by about an inch from my left hand. I used the tail stock for support until I had only a very small button left in the middle. The whole thing ran very smoothly with no vibration. Cant you tell I am a happy customer. It didnt really take me that long to make either. Just thought someone might be interested. Jared
Re: longworth chuck
Re: longworth chuck
Ron McKinley
>Great work! I keep collecting plans for one of these but doubt my ability to execute them accurately.
Re: longworth chuck
Re: longworth chuck
Tom Vensel
>Hi ,
I also made a Longworth chuck and I think it works great ! I followed the plans that are on this site under "WC articles and reviews" . I actually made two of them .The smaller one can work with turnings between 3.5 - 7.0 inches and the large one is 16 inches in diameter and will take turnings between 6 - 13 inches . They are really not that hard to make . The directions were very clear . Thanks , Tom
Re: longworth chuck
Re: longworth chuck
bob davis
>i have had one made from plans in wc archives. had for about a year,,got rid of cole jaws
Re: longworth chuck
Re: longworth chuck
Joe Herrmann
>It's gratifying to know that the directions worked as they should. I don't know how many times I've reviewed directions prior to publication wondering if they would work. I try to make sure that the directions are logical and try to work the project out in my mind as I go through an article, but, until someone actually makes it, it's still a guess.
Looks great!!
Joe
