Photo question
Photo question
Photo question
Carole Valentine
>I am seeing more and more "artifacts" in my photos...usually teeny tiny red or blue specks (almost pixel size). What causes this? Could it be dust inside the camera? Something to do with the flash card? I have cleaned the lens and that doesn't help. It'a a pain removing them.
Re: Photo question
Re: Photo question
>Carol That's a new one on me. When you get dust on the sensor it usually shows up as dark patches. Noise, which is caused by shooting at too high an ISO usually appears as white spots but I suppose it could be colored spots. If your shooting at the maximum ISO this is a possibility. Hope someone else has some experience with this problem. Can you post a photo with the problem showing.
Re: Photo question
Re: Photo question
Carole Valentine
>John, I am shooting at 100 ISO. Next time I find them I will try to post so you can see what I am talking about, but I doubt you can see them at the resolution called for to post here.
Re: Photo question
artifacts
Carole Valentine
>This is the best I can do right now. I had already removed them from the other photo. Any sort of sharpening before they are removed really makes them stick out like a sore thumb!
Re: Photo question
Re: artifacts
>Carole I see what your talking about. Iso 100 should be as good as the camera will get. Do you know what shutter speed the camera is shooting at. Very long speeds sometimes cause something that looks like that. It sure looks like dust but I only see that on cameras that have interchangeable lenses.
Re: Photo question
Re: artifacts
Carole Valentine
>Have to check what the shutter speed is. I have been setting the aperture (?) and the camera sets the speed. Aperture has been F8
Re: Photo question
Re: artifacts
>If your using the 300 watt quartz work lights your shutter speed is probably shorter than 1 second which I wouldn't think would cause a problem. Just for interest sake pick a bigger f stop which will shorten the shutter speed and see if you still get the same artifacts.
Another thought. If it's dust on the sensor the artivacts will be in the same spot all the time. If it's noise or something electronic I would think the spots would move. Shoot several photos and see if the spots stay in the same spot.
Re: Photo question
Re: Photo question
Dale Sherman, Manlius, NY
>You may have a problem with the CCD which interprets the light into a digital signal. This is likely if the spots are in the same relative position in every photo.
Good excuse for a new camera in that case.
Dale
Re: Photo question
Re: Dale is on the right....
JamieDonaldson
>......path here Carole. If the artifacts repeat in the same location in other photos then you have some dead sensors in the chip, and the fact that these are red makes it even more suspicious. Don't waste money on repairs- buy a new camera.
Re: Photo question
Re: Photo question *LINK*
DD
>You may want to try the link below. Although it is a camera review forum, there are also plenty of forums that pertain to general photography issues. Post a query there and someone is bound to help.
Doug
http://www.dpreview.com
Re: Photo question
Thanks, guys.
Carole Valentine
>Looks like it is the CCD since the spots appear mostly in the same places. I once considered a dcam to be luxury rather than a necessity, but with this turning addiction, that has changed so I guess I will start the new camera researching. Just what I needed right now :(
Re: Photo question
Re: Photo question
Larry Mart
>Carole,
The square red dots aren't artifacts, they're called stuck pixels. They are on the sensor and nothing can be done about them except clone them out on the picture or replace the sensor. Most cameras, LCD monitors, LCD TV's have one or more and they can usually be ignored.
Larry
(the other woodturning photographer)
Re: Photo question
Re: Hey Larry- what new digital .....
JamieDonaldson
>....camera are you using these days? Haven't heard from you in a long time!
Re: Photo question
Larry Mart
>I still hangin' in there. My health problems flared up for awhile and now I'm fighting congestive heart failure which is keeping me from working the AAW Symposiums anymore.
As for cameras, I'm totally digital now and currently using a Nikon SLR.
I hope to be able to do more photography and more turning in the near future.
Thanks for asking....
Larry
