ADVERTISE HERE - FREE TRIAL
hives
hives
hives
ken chase
>I suspect hives to be a result of allergy to solvents. Can anyone recommend a good waterbased clear gloss finish that comes in a can?
Thanks
Re: hives
Keith Tompkins
Re: hives
Keith Tompkins
>Ken, would you consider using wipe on oil finishes...they work well, and help aleviate many health related issues. The results can be quite stunning, and won't chip or crack.
Re: hives
Re: hives
Ron McKinley
>Many years ago I developed an allergy to mineral spirits. Probably because I didn't use gloves and it was absorbed into the skin. I didn't get hives but got a severe headache and fatigue. I gave up petroleum based finishes and switched to Varathane water-based poly. Works great but takes many coats to build a finish.
In our desert climate you can add another coat about every 5 minutes if you finish on the lathe and rub out so you may want to try it.
I'm back to petroleum-based finishes now(primarily Watco)now with the advent of easy access to latex gloves. I also run the fan/heater/air-conditioner and/or open the door when finishing.......Ron
Re: hives
Re: hives
tm
>rockler wundercote ... waterbase gloss
comes in a plastic squeeze bottle
this link is crazy-long i hope it works, if not go to rockler.com
and type wundercote into their search engine.
http://www.rockler.com/product.cfm?page=10555&SearchHandle=DADBDADJDADADDDGDJDHGFDFDJGGGGDICNDFGDDADDCNDEGFGFGECNDIGCDDGECNDIGCGBDBDHDHDGDIGGDHDIGBDADADADBDADADADBDAHHHFGOGEGFHCGDGPHEGFDADADADEDADADADADADADADBDFDADADADBDADADADADADADADADADADADADBDADADADBDAHHHFGOGEGFHCGDGPHEGFDADADADBDB
Re: hives
Re: hives
tm
>Just another thought... what kind of wood were you spinning?
some of the exotics, Cocobolo for example are notorious for
causing rashes and giving some of us the heebeegeebees....
tm
Re: hives
Re: hives followup
ken chase
>Thanks all. I've actually been working with jakaranda. It could be wood causing my problem but I think it's more likely the solvents. May never know!
Re: hives
Re: hives
Ed Heuslein
>Howdy Ken: Seems like you got every answer but the one you asked for. I use Crystal-Lac, available from McFeeleys and Klingspor's. A good friend uses a water based lacquer from Highland Hardware. It's a little cheaper and uses water to thin as opposed to the manufacturers "reducer" with Crystal-Lac. Both seem to work well. You can wipe on or spray. Dries in minutes. Dries clear and doesn't darken with age. I often use tung oil as a first coat to bring out chatoyance (thanks for that word Russ Fairfield). Then several coats of Crystal-Lac and finally Micro-mesh then buffed with Carnuba wax.
Re: hives
Re: rosewoods
>Jacaranda is usually a synonym for Brazilian rosewood, Dalbergia nigra. This species is closely related to cocobolo, Dalbergia retusa. While cocobolo is the most notorious, any of the Dalbergias can easily induce an alergic reaction.
You might try using the solvent in question with a wood that is much less likely to induce alergic reactions, like maple.
