Super Spalting Solutions
Rick Davenport
>I've got a couple of pieces of spectacularly spalted birch.
But it's so punky that I can literally remove chunks of it with my fingernail.
Is Polycryl worth buying/trying?
Will it stabilize my supersoft wood, or should I just save my time and money and burn that hunk o' birch?
Or is there some other method to harden it?
Rick
Re: Super Spalting Solutions
Allen Neighbors
>Rick, do a search here on WC for 50/50 White Glue, or something similar to that.. white glue, anyway.. There are a couple of postings about that solution for punky, spalted wood. I believe it was a posting by Russ. It was very informative.
Hope this helps.
Allen
50/50 white glue solution---Wally?
Molly Winton
>The 50/50 white glue (i.e. Elmers) solution is Wally's concoction. You just mix a solution of 50% glue with 50% water and then soak the piece over night (I believe that's all the time you need) and let it dry. The glue holds the piece together nicely. I'm not sure whether Wally recommends rough turning first, because of penetration issues though. Hopefully he will chime in here to clarify.
Re: 50/50 white glue solution---Wally?
Gary Evans Tallassee, TN
>You are correct, Molly,
Wally is the one who brought us this method. 50/50 white glue and water used to soak a punky, rough-turned form for 24 hours before drying.
Just speaking from experience, though, if you can peel off material with your nail, you may have to go through more than one soaking to even get it to the point of being roughed out. You can drag pretty good chunks out of punky wood, even with sharp tools.
I don't sell a piece of spalted wood which is that soft. Many turners would find it unworkable. I usually put it in the "not for sale, maybe I'll give it a shot one of these days" pile when I can make a dent with my thumbnail in the softest material.
Good luck, though. You might have something spectacular if you can tame it. Some of the prettiest pieces are the softest and, therefore, hardest to work with.
Gary
Wally Dickerman in Arizona
>Rick, sounds to me like what you have isn't even good firewood.
I've done the 50/50 glue soak a number of times with varying rates of succuss. If you can carefully rough turn it without tearing chunks out of it, it's worth a try.
When you rough turn it, the wall thickness will depend on the kind of wood, how wet/dry it is, and the size of the piece. I soak it in the glue solution for 24 hours. I haven't experimented with doing it for a longer period. It will soak up water, especially the punky part, so plan on some warping. Depending on how wet/dry the wood was before soaking, the drying time can run from a few days to a few weeks.
The glue soak will affect the finish. You won't get as much gloss, but otherwise it'll finish okay.
A big plus is that small crack will usually disappear. The wood swells and you're soaking it in glue.
I store leftover glue solution in a gallon clorox jug.
The cost of a couple of quarts or a gallon of white glue isn't very much at a big box store.
Wally
Allen Neighbors
>Sorry, Wally and Russ. My memory ain't what it used to be. :o)
Allen
>Rick, unless at least 50% of the wood is fairly solid wood I'd suggest that you toss it. The glue solution doesn't work magic.
Wally
Rick Davenport
>Thanks Allen, Molly, Gary and Wally.
I think I will give this a try.
The spalting is spectacular and what have I got to lose?
So nobody uses polycryl?
Rick
