Help with orange
Help with orange
Help with orange
Bob Fawcett
>I bought a block of cocobolo on ebay. It came nicely sealed with something that has an orange-yellow color. Now that I am turning it, I am finding orange splotches all over the wood. Its like this stuff splatters on the wood and leaves its color imbedded in the wood.
What could this be and how do I get rid of it. It doesn't look very good, this cocobolo is very red and the orange clashes. I don't think this is part of the wood.
Re: Help with orange
>Try mineral spirits. It removes most waxes.
Bob Fawcett
>Mineral spirits doesn't seem to affect it.
Could it be shellac? Is orange shellac that orange?
I'll try to post a picture
Carole Valentine
>You might ask the seller what they are using as sealer. Once you know what it is, it will be easier to figure out how to remove it.
Bob Fawcett
>Here is a picture.
I will also see if the seller can tell me what it is.
Thanks
Gary Evans Tallassee, TN
>Hi Bob,
If it's shellac, alcohol should cut it. If that doesn't work, I would try acetone, lacquer thinner and naptha. Unless it is a dried epoxy or somesuch, one of the common solvents should work. If none of those work, you may have to try one of the heavy duty strippers.
By the way, unless you are buying from the importer, it's unlikely that your guy will know what the wood was sealed with. The typical exotics, like cocobolo, are usually sealed before they are shipped. Still, if you have a cooperative seller (hopefully you haven't left feedback yet 8^}) he may be willing to work back to the source and find out what you need to know.
Good luck,
Gary
RK in Milw
>That orange color is oxidation of the wood. I always liked the way it looked and was disappointed when it would go away as I turned the wood. It will come back after the piece sits for a while. Exposure to sunlight accelerates the process.
Ron
Joe Herrmann
>I've had the same problem with cocobolo myself. My supplier tells me that it sometimes depends on where the wood was grown. I know cocobolo from Central America has more of a problem with the orange splotches than that grown in Mexico--at least that's been my experience.
Joe
