Grex RO sanders
>Anybody own one of the GRex Random Orbit air sanders. I've been wanting to switch to RO sander for larger work and that looks interesting. I saw it in the Packard catalog.
Grex RO sanders
Re: Grex RO sanders
Donna Banfield
>I have one John. I like it alot, but I had to 'learn' how to use a RO air sander. The style of sanding is more like a finesse. It works best, I've found, if you use is with 220 grits and up. So I use a corded drill for the lower grits and switch to the Grex at 220.
Re: Grex RO sanders
Russell L. Babbitt Jr.
>I did just recently get one and as it is a very nice tool. I got it in hopes of replacing my Souix and drill. I am on my second Souix because of a broken fan because of debris that got inside. My current one has noisy bearings because of dust, but if I blow it out it runs ok. The only thing so far I do not like about the Grex is that it is not reversible which I find very important.
Re: Grex RO sanders
>Interesting I would think a RO sander would be better in the lower grits than a drill. Thanks for the insight.
Re: Grex RO sanders
>On a regular drill I find reversing esential. Especially when I power sand my hand mirrors. Of course with a RO sander I might not have to sand with the lathe on. I notice they also sell a reversible air drill.
Re: Grex RO sanders
Bill Grumbine (Kutztown PA)
>Hi John
I bought a Grex sander back in October at the Albany symposium. At first I was disappointed with its performance, but I was expecting it to replace my Sioux. It does not. The orbiting action is very small, something like 1 mm.
Like Donna I use my Sioux for sanding up to 220 or so, and then switch to the Grex. While it only rotates in one direction, I use it with the lathe either turning very slowly or not at all. Using the two tools in this combination has improved both the speed and quality of my finishing.
Good luck with your decision.
Bill
Re: Grex RO sanders
Juergen
>I've had mine since last June. Using it has definitely improved my finishes. The use of this tool requires some new techniques. The need to reverse is academic with the RO. If you feel strongly about reverse sanding then one can reverse the lathe.
A much overlooked feature of an air tool is that it can freewheels, so it can be used like a passive sander, a la Vic Wood's design. As with any RO sander too much pressure will cancell the RO action. This in fact is good, since it will prevent heat from sanding and the resulting case hardening. To optimize the RO action I recommend manually turning your piece by hand and only use power when sanding in passive mode. I have been able to cause RO sanding in passive mode by making the point of contact the center of the sanding pad and not the edge, however, it doesn't remove as much material.
Re: Grex RO sanders
OB OBrien In Pensacola
>John; I have one and have coupled it with the new ASAP blue sanding discs. It's small, light weight and works great. However it does use a lot of air. Like the other responders have said, I use the regular drill to sand up to 220 then switch over to the finer grits.
I blow off all dust and reverse the lathe between each grit change.
Re: Grex RO sanders
Pascal Oudet
>one thing that has not been mentionned is that the pad (some kind of rubber) is quite hard. I am used to the soft one of Tim Skilton's sanding pad, and it was quite a surprise.
Of course I could replace it, but I've not tried that yet.
Pascal
Re: Grex RO sanders
Randy Privett
>I threaded the 1/4 inch shaft on the 2 and 3 inch sanding pads I get from Industrial Abrasives. That gives it a little more forgiveness.
Randy
Re: Grex RO sanders
Stuart Johnson
>I use an inerface backing pad between the Grex and the sandpaper. Packards has them in firm, soft and extra soft. I also use my Grex with the coarser paper usually letting it freewheel as a passive sander.
Re: Grex RO sanders
Juergen
>Don't get the real soft ones, they will distort and flatten out at high RPM.
