2 Stars
Phil Joines Krum, Texas
>Here are two of the sanding stars. The complete ones are 1/4" by about 4" and 6" long. The other one is 3/8" x 12".
I used drill rod because it was handy, cold rolled would work just as well. If you use drill rod don't let it get hot while drilling, it could harden on you making tapping impossible.
The screws are 10-24 x 1/2" round head. Use a new tap. Dull taps are almost guaranteed to break in a deep hole. I use a #25 bit to make tapping a little easier. A #24 is standard. These are threaded about 3/8" deep.
The short piece is the hole cutter for the sandpaper. It's 1/4" W1 with a #4 hole. The drill came out the side while drilling which I thought had ruined it. Not. Turns out it makes it self cleaning. After drilling the end was tapered to an edge with 320 grit paper. It was then heated to bright cherry red and quenched. A few slots were cut with a Dremmel cut off disk. It will cut through a whole stack of strips at once.
I haven�t tried this but when sanding something a lot larger than the star adding foam disks to the shaft to stiffen the paper might make it work better.
