carter bearings for bandsaw
Ed Karch
>Back when I thought the world was flat I installed carter blade guides on my old jet 14" with riser block for cutting veneer. One of the bearings lost it's shield and seized up. I miked it for size and looked it up to find that a metric 8id 22od 7wide is the common size for inline skates. A trip to the sporting goods store and I now have all new bearings with steel shields instead of rubber shields. There are 10 bearings in all on the carters. A package of replacements for your sKates is 16 bearings leaving six to make vacuum chuck rotaters.
Keep em rolling
Ed
Re: carter bearings for bandsaw
Rick in Colgate, Wi
>How interesting you should post that. Just yesterday I looked up some replacement bearings for my Grizzly bandsaw and discovered that the size is common to inline skates, which I had a used pair of for using the rollers for a lathe steadyrest. Plenty of extra bearings on hand now. By the way, Grizzly wanted $5 each for new bearings.
Ken
>WOW that really surprises me.I have used carter on industrial mach for years and never had one go bad on me,but then that was a few years ago.
Ken
Re: Surprised at the switch from seals to shields.
Al Crandall (NE of Indy)
>I thought that rubber seals were better protection in dusty atmospheres than metal shields. Am I wrong?
Re: Surprised ? ... you are correct
Ed in Leaside (Toronto, Ontario)
