Re: vfd
Bill Howatt
>I had an off-shore copy of something like a Jet1236 with Reeves Drive. It didn't look real easy to me to change the pulley to a step pulley but I didn't try it. I did fool with a different motor, step-pulleys and a jack-shaft arrangement driving the spindle reeves pulley. It worked but needed a lot more engineering to make it convenient. Also, I learned that there is more to a good lathe for heavy blanks than just rotating more slowly.
It may or may not be easy to use the reeves motor pulleys you with a different motor. Mine had a very long keyed shaft. However, if you mount the new motor with a same width pulley in such a manner that it will keep the belt tight, perhaps by its weight like a contractor's saw, or springs, you should be able to use the Reeves system.
By allowing the motor to run at a higher rpm for a given spindle rpm you will indeed get more torque from the ratio. Higher motor rpm will allow the motor's fan to cool it better and also run in a more optimum part of the motors torque curve. My 20" General VFD has 4 step pulleys with the VFD.
Good luck,
Bill
