thoughts on alcohol
thoughts on alcohol
thoughts on alcohol
jared
>remove 1 for email
Hello: My mind really started to ramble a few days ago when I was in the local hardware/farm supply looking at the cans of alcohol that I usually buy for around $9 per gallon. All of a sudden it hit me. I am a farmer and I grow corn and soybeans. I sell most of my corn to an ethanol plant where it is turned into ethanol and several byproducts. I sell a bushel of corn for about $2 which is then turned in to about 3 gallons of ethanol and about 30 pounds of livestock feed. Then the alcohol is shipped mostly to california by rail these days to be blended with gas in a 90-10 mix and sold for about $2.50 a gallon. Here in Iowa the 90-10 mix is available most everywhere and locally you can also buy E-85 which is a mix of 85% alcohol and 15% gas which is even cheaper yet, probably about $2 a gallon now. I talked to my local fuel supplier thinking maybe I could get some of that $2/gallon alcohol but they buy it already blended. He did say he thought he might be able to get a 55 gallon barrel of it. Then I got to thinking what would be wrong with just using the E-85 blend to soak my bowls in. It probably wouldnt be much different than alcohol and mineral spirits. Has anyone else ever thought of this and tried it? I guess I wont know with out trying it myself if there is too much or a residual odor in the dry bowl. I would think that 85% concentration of alcohol would be enough to expidite the drying process. I would think that the finishing coats of a shellac based sealer and 3 coats of my witches brew would be enough to seal in any smell or potentially unpleasant components of the small amount of gasoline. For that matter people use mineral spirits, mineral oil, and all sorts of petrolium based products in the finishing process.
Any thoughts on this? Am I way off base? Thanks in advance Jared
Re: thoughts on alcohol
which is it?
TDaniel
>85% gas and 15% alcohol or 85% alcohol and 15% gas?
Re: which is it?
jared
>Sorry, I must not have been clear, it is 85% ethanol and 15% regular unleaded gasoline. Jared
What about other additives?
James McClure
>Don't they put stablilzers, detergents and stuff like that in it to stop your valves from knocking, keep your engine running smooth, and prolong engine life? If so, I would be somewhat leery using it on something that someone might eventually eat out of. Just a thought.
Phil Joines Krum, Texas
>How about making your own? "Sour Mash" bowl series.
Re: Dyes also..
>For the dark stuff it might not matter, but for "white" wood, I'd be leary of the dyes migrating into the wood.
Steven Antonucci
I'd build a still before I soaked my bowls in gas.
steve antonucci
>Might end up with ATF on your doorsteps, but I'd bet you could build a "temporary" still to make your own alcohol in as needed batches. Just keep the empty cans from the Home Depot for storage and plausible deniability if ATF gets wind of it.
Steve
Honest Officer, I was just making alcohol....
TDaniel
>to soak wood in. Why do they call it "wood alcohol" anyway?
Re: They used to get it from trees
>If you can imagine distilling a tree (boxwood). That's methanol or methyl alcohol that is called wood alcohol.
Greg in Oshkosh
>I would worry about the odor from the gas. There are some gas byproducts that smell. I don't know if they would leave wood odor free after a few weeks or would the piece smell forever???
I would sure try a piece of firewood before I risked some good wood.
The other possible problem would be if some of the wood components are soluble in the gasoline portion. This would extract these compounds and at least migrate them throughout the piece.
All in all I think it's an idea worth a try.
Yes, the additives would be bad for your health.
Eddie Pacheco, San Jose, Ca.
>There are some really nasty chemicals in fuel and they can lead to systemic problems from ihhaling and touching too much of the stuff.
I think the alcohol still approach is the way to go as it doesn't take too much equipment to set one up. And --- you can burn your scrap wood and mistakes to fire it.
jared
>I just picked up a couple of gallons of the 85%ethanol mix. It is nearly clear, I dont think there is enough color in it to bother. It is more clear than my alcohol tub is after I soak a few blanks. It does have that unmistakable gasoline odor though. I guess I will rough out a couple of small ash bowls this afternoon and let them soak over night and see what they smell like after a week or two. And then the least Ican do is to dump the mix in my pickup and use it up that way so I am not really out anything for the experiment. I have an idea that the odor may be more of a problem than anything. Jared
Re: thoughts on pick-up
>Jared,
Do not use the portion that you use to soak the wood in your truck. It will have wood extractive compounds, including sugars, in solution that will likely do a number on your engine.
Re: thoughts on alcohol *LINK*
Mark Wollschlager
>I would treat the bowls as if they were gas soaked rags.
According to the MSDS %15 gasoline in ethanol lowers the flash point below 0 ( DNA is around 55 ) and increases the vapor pressure way above DNA.
Hot sparks from grinding, heaters, Danger Will Robinson.
No matter how thin you slice it its still gasoline.
Mark
MSDS for E85
Steven Antonucci
Also covered on MythBusters...
steve antonucci
>Apparently, putting sugar in a gas tank doesn't do anything at all... Jamie and Adam poured a whole bag into a running engine and nothing happened.
Steve
