Bast Sandpaper for Wet Sanding
Doug Reynolds in Seattle
>Looking for recommendations for sanding paper to use on green (wet) bowls and the like. The usual stuff sure loads up fast.
Re: Bast Sandpaper for Wet Sanding
Carl Ford
>I like the 3" White Rhyno disks avaialble from Packard Woodworks Inc. http://www.packardwoodworks.com/Merchant2/merchant.mvc?Screen=CTGY&Category_Code=snding-adiscs-whirhy
They work fine, even after I get them wet. They last a long time.
Any "J" backed sandpaper will works fine for wet sanding. J backed paper is what they make belts out of for Belt Sanders. Some of tyhe J backed stuff is way to stiff, the softer stuff is better. The only way to tell is buy it and try it. The J backing is a cloth backing.
The Klingspor "Gold" sheets are J backed cloth sheets. They work real good. They also work dry on wet wood with less clogging. www.woodworkingshop.com
I just noticed that Klingspor now has there "Gold" paper in 3" hook and loop disks. I have never tried these but they are probably work good. Like the White Rhyno disks.
I use the Klingspor 3" STEARATE HOOK & LOOP DISCS for wet sanding. They are not J backed, but they last long enough to ge the job done.
>Doug I have used the mesh sandpapers by Mirka. It's called Abranet. It's kind of expensive and hard to find. Do a search for Mirka Abranet and you may find some. You can find the same thing in course grits at your home supply, it's used to sand drywall. It looks like wire screen.
Most of the time I just shear scrape and then wait until I have the inside of a vessel turned. By then the outside has dried sufficiently to allow sanding.
RussFairfield
>Doug,
You can wet sand with any sandpaper or sanding disc. The only difference will be that the glue will not be waterproof and the grit will come off. That doesn't stop the disc or paper backing from sanding the wood with the slurry of grit and water, but it does mean that it cannot be reused again, and you will have to flush and clean the wood before going on to the next grit.
The real advantage is that you will have 60, 80. and 100 grit sanding discs or paper to use with water and without buying anything special.
Re: Bast Sandpaper for Wet Sanding *LINK*
Matthew fallon(long island ny)
>i really like the abranet stuff'
havent used it on really green wood yet.
got it on ebay from a woodturning supplier in the UK as a sanding kit with other supplies.
recently found a place near me in NY that sells it ,havent bought from them yet but our woodworkers club president had good dealings with them.
http://www.colorspeccoatings.com/
