Looking For T. Daniel
W.C. Turner
>Terry,
I was looking thru the archives, & saw some mention of you turning & holding the handle down, low. Do you try to make your gouge grind to imitate Ellsworth's signature grind? And, Have you seen his video/CD about the way he uses his bowl gouge?
I mentioned these things in order to ask you, if you rough your bowls inside, & out, & then finish turn them, by holding the handle down low, during the entire process?
As, opposed to Ellsworth's method of using his signature gouge, by holding it more level, or horizonal, for the roughing cuts, but, uses the one gouge for the entire process.
I'm just trying to figure out, or, rather asking how much your style differs from the way Ellsworth does it, in his Signature Bowl gouge use video?
Thanks,
W.C.
Remove the spam for mail
Re: Looking For T. Daniel
I have never seen the Ellsworth video
TDaniel
>other than about 3 minutes one day at a Woodcraft store when someone else was watching it. Generally, I keep my handle low except when a piece must be absolutely round. The advantage of the low handle position is the tool will push back out of the cut when an area of tough grain comes around, thus eliminating catches. Also, cutting with the side of the gouge instead of the tip gives a slicing cut instead of a shearing cut and puts much less pressure on the bevel so you don't get the burnishing or bruising of the wood. I plan to demo the bowl gouge at our Gathering next month. You can see my grind in the "Grinds library".
TD
Re: I have never seen the Ellsworth video
>Terry If the tip is held correctly is also gives a slicing cut. The cutting angle would be essentially the same. The main difference is the lower wing will remove the bulk of the wood while the tip does the slicing cut.
