Food safe sanding sealer?
Dominic Greco in Richboro, PA
>Hi everyone,
Sorry for the brevity of this. I gotta be quick since I'm at work.
I was working on a Silver Maple salad bowl last night and ran into some trouble with end grain. Even with some judicious use of a shear scraper, there were areas that I could not get rid of the end grain issue. It's right up against an raised area on the bowl rim that will featured some texturing bordered by some beads.
If this weren't a "food grade bowl", I would wet sand with Russ' 50 varnish/50 mineral spirits mix. I'm sure that would work. But I'm concerned about the varnish coming in contact with the food.
Does anyone know of a "food safe" mix, that would seal the end grain effectively, and I could use to wet sand?
Thanks in advance.
See ya around,
Dominic
Re: Food safe sanding sealer?
Ruth NIles
>Hi "Dad",
Wouldn't some sort of shellac finish work?
RussFairfield
>All you are trying to do is fill the grain. There are a lot of options for doing that. Here are some of the choices.
You can use Mineral Oil. It is edible. I buy it at the farm store in gallon jugs. It is used as a laxitive and tonic for horses.
How about Paraffin or beeswax? Buy the paraffin at the grocery store, heat it and apply, and there are no solvents.
A lot of woopdtrurners use Johnson's Paste Wax or Trewax to give body to the end grain. You can eat either of them oput of the can. It might not taste too good, but there are no poison labels on the cans.
How about a lacquer based sanding sealer. Lacquer solids are celluloid. The filler is stearic acid, and that is an ingredient in hand soap - edible but doesn't taste very good. I would wait for the lacquer thinner to evaporate before trying to eat the wood.
Shellac is 100% drinkable in its liguid form if you used EverClear (Straight Grain Alcohol) from the local liquor store as the alcohol solvent. You might want to wait for it to evaporate if you used denatured alcohol.
The solids in a varnish are inert. If you used Turpentine as a thinner, it is an ingredient in many cough syrups. If you used Mineral Spirits or kerosene, either will give you an extreme intestinal distress, but neither will kill you.
Re: Food safe sanding sealer? *LINK*
georgetroy
>You can use Preseve which is safe for woodenware to seal and finish. It can be purchase from Kingspor's. Their shipping is only $6.00 lowest price on the web. Listing source.
Klingspor's Woodworking Shop
Bill Hale
>Dom
Per Gov. Regs all finishes are food safe after they have cured.
Good turning and be safe
Bill in Casa Grande, AZ.
Hi Russ
Dominic Greco in Richboro PA
>Russ,
Thanks for responding.
You wrote:
"All you are trying to do is fill the grain....."
That's right. I was just trying to fill the end grain to stiffen them up so they would "cut" smoother and yield an ultra smooth surface.
You wrote:
"How about a lacquer based sanding sealer. Lacquer solids are celluloid. The filler is stearic acid, and that is an ingredient in hand soap - edible but doesn't taste very good. I would wait for the lacquer thinner to evaporate before trying to eat the wood."
Am I correct in assuming that a lacquer based sanding sealer is the same as thinned lacquer? If so, I have some lacquer and thinner on hand I could use. My thought would be that I would have to wipe the bowl down with thinner after I'm done wet sanding and allow it to cure for a 2 -3 days.
I wonder if wet sanding with thinned lacquer would interfer with the application of some type of salad bowl finish? My gut says "No." Because this would be like a sealing coat (but then again, my guts been wrong so many times!). My Mom prefers Walnut oil. But that "Preserve" from Klingspor, or Mike Mahoney's Salad bowl finish would probably do.
You wrote:
"Shellac is 100% drinkable in its liguid form if you used EverClear (Straight Grain Alcohol) from the local liquor store as the alcohol solvent. You might want to wait for it to evaporate if you used denatured alcohol."
NOW there's a thought! If I don't like the bowl too much I can always mix the Everclear with some Pedialite (now that the baby is here, we got that all over the place) for a nice stiff drink.
Actually, I considered shellac, but wondered how well it would stiffen up the end grain. I'll have to keep this in mind.
You wrote:
"The solids in a varnish are inert. If you used Turpentine as a thinner, it is an ingredient in many cough syrups. If you used Mineral Spirits or kerosene, either will give you an extreme intestinal distress, but neither will kill you."
This was my original thought. A couple years ago I used your 50% Varnish (w/alkyd resins) / 50% mineral spirits to wet sand a walnut bowl and it came out fantastic. But you're mention of the use of turpentine sounds like a better idea.
Thanks again for all the great tips.
See ya around,
My ugly mug
Dominic
Thanks Bill!
Thanks for the tip George
Hi Ruth
>Ruth,
I figured shellac would work. But I was wondering how much I'd have to thin it down. I tried it once before and found it a bit "gummy". Probably should have added more alcohol.
See ya around,
Dominic
