CA problem
CA problem
CA problem
Richard Jones
>OK, turning a bowl from really old, really dry walnut. Previous owner had this chunk glued up from three pieces. I am using walnut dust and thin CA Gold to fill the cracks. Looks like the CA really penetrates deep and spreads out, causing a huge stain, forcing LOTS, and I mean LOTS of sanding. Would a thicker glue work, use accelerator, or just use some white glue and dust? Is this occuring because it's dry or because it's walnut? This stuff seems thinner than the Elmer's CA I got from Lowe's.
Aggravating to get a nice looking shape then have to put 60 grit on it to remove the darn CA................
Thanks.
Rich (always having fun) in VA
Re: CA problem
no guarantee but....
TDaniel
>try sanding with oil, something like Watco Danish.
Re: CA problem
Ric Taylor
Re: CA problem
Ric Taylor
>Richard,
You should seal the wood before putting on the CA glue. Put on a good coat of sanding sealer, or a good coat of a 50/50 mix of lacquer and lacquer thinner. Another option is to put on a coat of whatever your final finish is going to be. Then when you put the CA in the crack, it only fills the crack and doesn't penetrate the wood. When the CA dries, do whatever sanding is necessary, then proceed with your normal finishing technique. This will greatly reduce or eliminate the staining that you are seeing, because the CA won't penetrate into the wood.
Good luck,
Ric
Re: CA problem
Re: CA problem
Carole Valentine
>Richard,
When I have to use CA, I use a coat of paste wax or Watco Liguid Wax over the area to be glued and the surrounding area. It does not penetrate deeply so the wax comes off easily with final sanding but it keeps the CA from penetrating areas other than the crack. Of course with some really punky, dry, porous woods the CA will wick out beneath the wax from the crack. Best bet then is to use an oil finish over the entire piece before using the CA as TD suggests, but then I wonder how the oil affects the bonding of the CA.
Re: CA problem
Re: CA problem *LINK*
RussFairfield
>The thicker the CA glue, the less ir wicks into the surrounding wood.
The only reason for using CA glue to repair the wood is because it is faster. You have discovered the price that must be paid for that speed.
There are still a lot of reasons for using the old-fashioned methods for filling cracks with a mixture of white or yellow glue and sawdust, and wet sanding with the finish. Both require waiting for the glue to dry; but there is no wicking or stain, and it isn't necessary to precoat the wood before using them.
Have you read my article on glues in the Wood Central archives. It begins with a discussion of why CA glue might not be the best glue for turned wood. It mighjt be helpful.
http://www.woodcentral.com/russ/russ6.shtml
Re: CA problem
Re: CA problem
bob davis
>for years i mix wood dust with cement for wood modes tomake a paste to fillcracks,always sealing first.dries fast sands well
Re: CA problem
Thanks to all.......
Richard Jones
>All good advice, I appreciate it.
Rich (looking for sanding sealer) in VA
