Vibration Hollowing Bowl
Barry Turner
>I put my roughed-out box elder bowl back on the lathe yesterday. Its about 10" in diameter by about 6" tall. It had dried some, so I had decided to thin down the walls to hasten drying by taking a few hollowing cuts off the inside of the bowl. Although the bowl walls are well over an inch thick (1 1/8"), I get a low frequency vibration when I start the cut near the rim of the bowl. As I near the bottom, the vibration diminishes and goes away.
The bowl is mounted in my Super Nova chuck with a 2" stub tenon. The chuck is tightly seated against the spindle....no plastic washer or anything. The 2" standard jaws are tight on the tenon. The tenon is intact....not cracked or anything I am no longer using tailstock support as the bowl is now hollowed. The Crown PM 5/8" Ellsworth grind gouge is freshly sharpened. Still I get the vibration. Any ideas would be appreciated. Thanks.
Barry
PS Is it time for me to invest in a new Stronghold chuck? Or, do I just need to put this blank on the drying rack, wait a few weeks and let it finish drying before I come back to it?
Re: Vibration Hollowing Bowl
Carole Valentine
>Did you try changing your lathe speed just a little, by any chance?
Barry Turner
>Oh, yes I tried that, too.
Keith Tompkins
Keith Tompkins
>Barry, I'll bet it's the wood itself...do you have a bowl steady? I hold my hand on the exterior of a bowl when that starts to happen...Only try that if you are comfortable with it.
Some woods will vibrate or chatter, some more than others.
Wally Dickerman in Arizona
>Sounds pretty normal to me. You say that you thinned the walls by taking some off the inside. If you take some off the the outside to bring it in to round, the vibration should go away or nearly so. Sometimes a bowl 6 inches deep could use help from a bowl steady.
Wally
>Barry Did you true up the tenon before you mounted it in the chuck. That will definitely cause vibration if you didn't. I usually remount bowls between centers on second turning and then true up the tenon and square up the shoulder.
Re: Vibration Hollowing Bowl *LINK*
RussFairfield
>Think about the two things that are happening that are making the bowl vibrate when you get next to the rim. The rim vibrates for the same reason that a bell rings - It is in tension. Relieve the tension, and the bell is "dead". As it dries, the wood at the rim is dryer than the rest of the bowl because it is drying on 3 sides, while the rest in drying on 2. Therefore it shrinks faster, and therefore it is in tension. That tension is what makes bowls crack at the rim, and it is also what makes them vibrate.
There several ways to relieve the tension at the rim.
Yow can put some water back into the rim, making it expand and relieving the tension. Putting it rim down on a couple layers of wet towel are a good way to do this.
You can wrap a band clamp around the bowl. Squeezing on the bowl behind the rim relieves the tension at the rim.
You can use a vibration damper. Rubber bands or slices from an innertube, or bungee cord are all good for dampers. Several wraps with the old fashioned friction-tape is a good damper, but it might be hard to find these days. Home Depot sells it.
Use your hand as a damper. This can wear the skin off the fingers if the outside of the bowl is rough, and it does require a one-handed bowl gouge technique.
Or, make or buy a bowl steady. I made my own long before Oneway made such a thing, and have never had a reason to buy one. See it at the link.
http://www.woodturner-russ.com/BowlSteady.html
Barry Turner
>You may be right. The wood is wet Box Elder. Thanks.
Richard Allen
Richard Allen
>Let the bowl dry. In six months the bowl will be mostly dry which will eliminate most of the flex in the bowl. When the bowl is dry use standard bowl turning technique. Work on the rim area first and proceed down the wall an inch at a time.
Good luck
Philip Duffy
>The only thing not mentioned so far, and it would only apply to a lathe that has a moveable headstock, is that the headstock is loose and adding vibrations to the problem. Obviously, if your lathe has a fixed head then my comments are to be disregarded.
>Philip Barry has a Stubby. It probably isn't the lathe. I always hate it when I can't blame the tool but in this case I'll bet it's not the lathe. Sorry Barry.
Bob Elliott
>Work your way from the rim to the bottom in steps. In other words, establish the rim thickness & advance into the bowl about an inch. Make a finishing cut in that area, then advance deeper about an inch, blend the two areas and continue the wall thickness on that second step, then proceed deeper with a third step, making your way to the bottom in continuous steps, blending / making that finishing cut as you go. Once at the bottom do not go back out to the rim.
Since You Mentioned That...
Barbara Gill, Remlik VA
>Back when I had my Nova 3000 I was having some problems with wobble. It turned out I had some sawdust build-up behind my chuck insert.
Barry Turner
>That has proven to be a real problem ever since I got this thing. I used to tell Joyce, "If I just had a better/bigger lathe......." She won't buy my stories any more either,
Barry Turner
>You're right on. And it works, too! Already tried another bowl using your technique. Thanks.
