Air Compressor Advice
dick gerard
>My current air compressor (Sears, 20 years old) is having last rites performed. Death is imminent. SWMBO has granted me permission to shop around for a replacement ... under $500.00, preferably less. Intended uses include powering air sanders, rotary carving mills (burrs), and general dust blowing, etc. i'm really good at getting dust to blow around!. Anyway, what should I look at? Upright? Horizontal? Dual stage? Single stage? Any advice appreciated ... even Jennifer's!!!
Re: Air Compressor Advice
Jennifer@Indy.USA
>Wise Guy, eh!
Dick, I've been real happy with my oiless upright 60 gal. Porter Cable. Bought it at Lowes a few years ago. I don't recall what I paid for it....but it was well below $500! The oiless are a bit louder than the other....but this one is not too bad. Much less noisy than my Craftsman pancake prior to it that died after a year.
It's late!
Jennifer : )
TDaniel
>Costco has a 5 gallon twin tank with a 2 hp motor for $98. I have been running one for about 6 months now and it seems to be a pretty good unit for the price. It is a piston type compressor. The hose connection fittings are poor so plan to replace them immediately but other than that I have no complaints. For a lot of use with airpowered sanders it will not be big enough to sustain long periods of sanding although you could connect to an auxillary tank and extend the time somewhat. Unless you need more than 120psi you will not need a 2 stage compressor. Upright or horizontal just depends on your available space. If you want to tuck it under a stairwell then you want a horizontal but otherwise the vertical will take up less floorspace. A used commercial duty compressor with cast iron pump and single phase motor would be worth searching for.
TD
Bob Fawcett
>For the work you describe airflow is more important than pressure. See if your air tools have a CFM requirement and use that as a guide. Most airtools run fine on 90PSI. If you use more than 1 tool at a time you need to add the CFM requirements.
Re: Air Compressor Advice *LINK*
Peter Teubel
>Any kind of air-powered sander will need copious amounts of CFM. Since you asked for suggestions, here's mine:
Get the most CFM (@90PSI) you can afford in a NON-DIRECT drive unit. The direct drive units are much louder and don't last as long (although that's not so much as issue for homeowner use). Ignore hp ratings...all mfg blatently lie about their power ratings and they mean absolutly nothing. Its CFM ratings that count.
The link below is the one I have and I am very satisfied with it. The 7hp rating is so far-fetched that it's in the realm of science fiction. It draws 16 amps at 220vac, so that translates to about 4.8hp (probably 4.5hp after internal losses). But it rated for 10.8 CFM @90psi, which is fine for my needs.
This is the one I have...
Bill Crommett
>LOUD ?? Any oil-less compressor is a hazzard to your hearing unless it is put in another room or an outdoor shelter.
I thought my old Sears was going to die one of these days so I bought a new "5.0 hp" oil-less that was so loud that I put it out in the barn to use only for airing tires. I then brought my old Sears piston pump into the shop to use until it really died. That was ten years ago.
Barry Turner
>I bought a Husky (Home Depot) 60-gallon upright last year that I have found to be perfectly adequate. It replaced a 30+-year old, 2 HP Craftsman with a twin cylinder compressor and 30 gallon tank that was on its last legs. It's tank had rusted through and as much air leaked out than was used.
The Husky is a 6 or 7 HP, (can't remember which, not that it matters that much with the way they rate HP these days). It is a single stage and has a 60-gallon upright tank. If you are concerned about noise, it is noisy, but the compressor doesn't run very much if you are only blowing chips off the lathe, etc. I haven't tried sanding or spraying, I think it would be up to most tasks in a woodturning shop.
David Galloway
>Highland Hardware is offering a system perfected by my friends Joe Matwick and Dave Hout that uses a compressor to create a vacuum for a vacuum chuck. It is a slick system that costs around $240 that is so simple. Call Highland for the info but they now have them in stock. Nick Cook used it at a recent woodturning demo and they were selling like hotcakes. Excellent engineering a la Joe.
David
