skew chisels and tool rests
arw01
>The jet mini lathe is pretty darn new, there are a number of "notches" or grooves along the tool rest. These catch the skew chisel. What have others done to make these less grabby?
Alan
Re: skew chisels and tool rests
tek-Brunswick, Ohio
>Smooth it out with a file! The rest should file fairly easily.
Russell L. Babbitt Jr.
>Filing or sanding your toolrest smooth is almost part of routine maintenance. If you have a skew with sharp square corners ty grinding or filing the edges slightly round.
>I agree with Russel. File or grind the rest smooth, anytime it needs it. Standard practice. Any tools with sharp corners, look at them closely and see if the corners "do" anything for the use of the tool. Took me a while to realize the only use I got out of the sharp corners on the skew was cutting unwanted grooves in the rest when I got a catch. It was HSS, so I ground the corners off slightly (maybe a 1/16" radius) on the grinder I sharpen it on. Big improvement. Slides better and more smoothly even when there are no notches in the rest.
Bob Fawcett
>I bought a modular tool rest for my jet mini. The rest is steel and doesn't nick quite as easily as the stock rest. Woodcraft carries them.
My skew is oval section, and that helps. I am new to this too, but the oval skew came in the Sorby tool set I bought with the lathe.
