Cole Jaws
Cole Jaws
Cole Jaws
Richard Jones
>Looking at some Cole jaws for my Midi for reverse turning, foots, etc. I see the way Ernie Conover does, but I don't mind spending the bucks for the jaws if they're worth it.
Comments, pros and cons, welcome, and thanks.
Rich
Re: Cole Jaws
Dick Hines
Re: Cole Jaws
Dick Hines
>Rick, I am a cheap turner. To reverse turn bowls I bought a piece of MDF, some sheet cork and a face plate. I cut the MDF round and screwed the face plate to the board. Then with contact cement I glued the cork to the MDF. Presto! Now all I have to do is place the rim of the bowl on the cork covered MDF bring up the tail stock and finish the bowl.
Colw jaws for a mini $60
Face plate $25
MDF board $10
Cork $5
Thats a $20 savings.
Re: Cole Jaws
Re: Cole Jaws
Bruce Wiseman
>Check out Darrel Felmate's web site www.aroundthewoods.com he has instructions for making Cole jaws. I have some that I bought before I found his site. You will need to keep the speed down and take very light cuts, otherwise you will launch the bowl. (DAMHIK). Lately I've been using this stringy plastic stuff, comes in rolls about 2 inches wide and streches like shrink wrap. A few times around with it between the jaws of the Cole jaws and the bowl is good and solid. I think Mike Swing or someone on WC suggested this a while back.
Re: Cole Jaws
Re: Cole Jaws
georgetroy
>Cole jaws are worth it. I use mine for segmented rings when needed. They will also serve as a centering device. You can place the buttons inside of a turning when sometimes you can't get a grip around, using them as expansion instead of compression. There is always alternate methods of reverse turning and some works better than others. I noticed the cole jaws are now being shipped with white buttons for the Nova. My Axminster jaws had those ten years ago. Of course in the money pit of turning it helps to have duplicates to speed up the processes. GT
Re: Cole Jaws
Re: Cole Jaws
Jim Ketron
>I love the set I made. Used them all the time, before I set up a Vac system.
The biggest downfall that I had with them was changing the jaws gets old fast.
Re: Cole Jaws
Re: Cole Jaws
dick mc neill
>I always find use for the Coles. I've got the Nova & two sizes of oneways. If you'd rather turn than make jigs, it's the best way to go. Some advice buy the oneway double button set, you won't be hostage to flat rims. Incidently I prefer the Oneway to Teknatool.
Re: Cole Jaws
Re: Cole Jaw buttons without Cole Jaws.
Al Crandall (NE of Indy)
>Sometimes a piece is just too small for the Cole Jaw buttons to grab, or maybe the opening into which you were going to expand the jaw buttons is too small to fit over the buttons when they are installed in the smallest diameter ring of holes. The screws which mount the buttons are the same size as the ones used to mount the various jaws to the chuck body. A few times I have had success by mounting the buttons directly to the chuck.
Re: Cole Jaws
Re: Cole Jaws
jared
>remove 1 for email
Where do you get the rolls of plastic/shrink wrap stuff? I have seen mention of this material before but dont have any idea of where to look for it. I am in the process of building a longworth chuck that was described in one of the turning mags an issue or so ago. I think it would be good to have something like that to use as a safety device on that thing too. Thanks in advance Jared
Re: Cole Jaws
Re: Cole Jaws *LINK*
>Richard Check out the reverse turning tip on the page below. It answers a lot of questions on reverse turning. I put it togethr just for this reason.
http://www.cumberlandwoodturners.com/tips.asp
Re: Cole Jaws
Re: Cole Jaws
Gary in Zirconia, NC
>Lowes has it in rolls as other places do to. I think it's about 14" wide and cost is about $15.
Re: Cole Jaws
Re: Cole Jaws
Brian Hahn in SW Wisconsin
>I bought my roll at Woodcraft a number of years ago. I think it was called "flat twine" or something like that.
The office supply stores (Staples, Office Max, Office Depot, etc.) usually have it in their shipping supplies section.
Re: Cole Jaws
Re: Cole Jaws
>I have a set of Cole jaws and like them. I got a larger lathe and found they were limited by their size. Made a set of extenders. Get a set of eight corner strap mending angles and cut one leg off about an inch long and bend it just past 90. Dip the short end in liquid rubber or wrap some tape around them. Mount the long side on the face of the jaws with the existing buttons and they work like hooks. I picked a set that extend the jaws to the maximum swing of my lathe. Actually, I was cheap and made mine out of a flat steel bar about 1" by 1/16". You can also turn them around and "expand" them into a bowl.
Re: Cole Jaws
Re: Cole Jaws Thanks John
Steve in NC
>John
Great article. Thanks for Sharing it. I have it printed and in my "things to remember" binder.
Steve
