Beginner questions
Beginner questions
Beginner questions
Bob Fawcett
>I am roughing out a bowl out of Black Cherry. Its about 8" and the wood is green. This is on my jet mini, so is large for the lathe. I have done the back and have it mounted in a talon chuck, but with the live center in the middle.
How long can I / should I leave the center in place?
How thick should I leave the rough bowl to dry?
Thickness should be fairly consistent to dry?
Once I have a rough shape, how should I dry it? Fast slow?
Re: Beginner questions
tek-Brunswick, Ohio
>The center makes helps hold the piece in the chuck if you get a bad catch. Some people don't use it at all when turning the inside of the bowl, and some people use it for the whole roughing process. Experiment and find out what you are comfortable with. The rule of thumb on the wall thickness is 10% of the diameter of the bowl. Example 1" wall for a 10" Diameter bowl. Go about 3/4" for 8" diameter. Dry it slow, for the first month anyway. Put it in a paper grocery bag and roll up the top. You can put some shavings in with it to to help even the drying. Some people coat the end grain with sealer also. A consistent thickness helps reduce cracking in the drying process. A lot of people use Dave Smiths alcohol drying process. I use it only when I am in a hurry. It does speed up the drying. Search the turning archives on drying and you will find out a lot of information. NO method works 100% of the time. Find something you are comfortable with and experiment from there. After all wood does grow of trees!
Tom
Carole Valentine
>Hi Bob,
On a bowl that size, I don't use the center for support at all as long as I have a good tenon in the chuck.
Normally I turn green wood to a thickness of about 10% of the diameter.
However, cherry, if it's like our wild black cherry, will warp and crack on you so I generally leave that a little thicker so I have plenty of wood to turn it true when dry (including the tenon). I boil my roughouts of fruitwood for 45 minutes or an hour, let them cool to room temp in the boiling water, surface dry, then follow the DNA soaking and drying process. (If you don't know about that, go to the Articles section under turning and look for Dave Smith's article on alcohol drying.)
Good luck!
Bill Howatt
>I agree with tek-Brunswick and Carole although I don't boil or booze my bowls hardly ever. I just put them in the bag with some shavings and leave in my basement for several months. I sometime seal the endgrain, sometimes the whole thing, sometimes nothing. The more I think the piece is a good one the more I seal and of course it takes more time to dry - more anchorseal, more drying time.
The tailstock makes it safer alright and if you are comfortable using it then by all means do so. I rarely ever use the tailstock on anything under say 14" and certainly wouldn't on a 8" bowl since I would quickly consider it in the way. I use Oneway Talon and Stronghold chucks (same jaw type) and you really have to get a bad catch to knock a bowl out of the jaws; usually they don't even run off true. I am speaking about external chucking, not internal chucking.
No hard and fast rule but if your feel uncomfortable then use it. Safety is never a bad idea.
Bill
Bob Fawcett
>Thanks Carole and tek.
I am goung to try tek's paper bag method. I don't have any alcohol on hand and I am not sure I am ready to tackle the DNA method yet.
Bob Fawcett
>Thanks Bill.
I used the tailstock about halfway. It does seem in the way soon. At first I thought I might need it since the jet mini is small, but having done it, I now think it was unecessary.
Thanks again to all who answered.
>We have a professional turner in our club who turns a lot of cherry bowls. He insists the chuck foot is where a lot of fairly serious cracking starts, so he turns it off and lets his blanks dry as round bottom blanks. He uses the 10% rule. He tries to leave a center mark on the bottom of the bowl. When he comes back to it he mounts it on a jamb chuck and put the live center in the tail-stock back against the canter mark. Checks it to see how badly it warped and re centers if necessary. Then he turns a new chuck foot on it. He seems to think you are going to have to go through almost the same procedure to true up the chuck foot and that he loses fewer bowl if they don't have the uneven thickness of the foot.
I don't turn as many as he does and I have not made the observation that the chuck foot is the culprit. I turn mine and usually make the bottom a little thiner than the 10% and some times leave the rim a little thicker. I find the bottom warps very little, but the rim may go crazy. I put mine in a brown paper bag and let them sit until I find them again. I have not boiled any, but I have used the alcohol and it works. Its a good idea to write the species and date on the blank. You will be stunned after a while to open a bag and wonder where it came from, how old is it and what is it and maybe what was I thinking?
Bill Howatt
>"... Its a good idea to write the species and date on the blank. You will be stunned after a while to open a bag and wonder where it came from, how old is it and what is it and maybe what was I thinking? "
On the bottom of the roughed bowl I write GTdate -1 GT means GreenTurned and the -1 is for the first one that day, -2 for the second etc. I have a notebook that I record the numbers in and anything I want about the wood.
A typical entry will read something like:
GTJune2306 Maple from Fred Jones. CA on bark and knots. I then leave a few lines under it so when it gets finished I will record the date and what finished was applied and anything else of interest, like filled with coffee grounds and CA. I also record what happened to it such as "Gave to Gwendolyn for 23 birthday".
Bill
